Anyone running these tires??
I found the Kumho Road Venture AT in 355/60/R20 and i was wondering if anyone had any experiance with them?
I also saw the Kumho Road Venture MT KL71 in 37X13.50X20 that seem to look really good....
just wondering if anyone has run them or knows about tread wear and noise levels compared to the well known Nittos and Toyos. Thanks, Jason
Those A/T look pretty agressive. You will get better wear out of an A/T over a full M/T. I've had Kumho's in 16 inch load range g and they wore pretty evenly. You will have to rotate those alot to keep from scalloping so make a good deal on rotation and installation at the start or the tires will haunt you pretty quick. With that width make sure the rim has the proper backspace offset to match. Good luck......How much did you find them for. I got Kumho's over Toyos because they were way cheaper.ks
I found the MT KL7's for 330.00 a tire in the 37X13.50X20 and the Road Venture AT's for 283.75 a piece for the 355/60/R20s.....doesnt seem too bad to me. Then i found a package deal with the 4 Kumho Road Venture MT KL7's and the Eagle Alloy 114s with the super finish in 20x10 for $2271.00 shiped, mounted and balanced. And with the Toyo Open Country AT's instead would be $2431.00. Both dont seem too bad to me....
May 29, 2009 10:24 PM
kawiram
Apr 3, 2007 11:36 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
Dodgezilla
Dec 8, 2005 02:22 PM
m3rd
Mar 16, 2004 08:30 AM
