amsoil remote filter
Old Mar 8, 2008 | 10:33 PM
82NDSNPR's Avatar
Question amsoil remote filter
can i mount the amsoil remote filter kit part number bmk-11 on the frame rail or do i have to mount the filter above the oil pan. the reason i ask is i have no room under the hood for this kit. and with the dual cp3s and twins going in i realy have no room in the engine bay for the remote kit.
Old Mar 8, 2008 | 10:36 PM
53 willys's Avatar
you can mount it any place you want...they suggest not mounting it to the engine.....and they dont want it mounted way down the frame rail either...but it can be mounted on the frame just get it as close to the engine as possible.
Old Mar 8, 2008 | 10:41 PM
82NDSNPR's Avatar
so on the rail by the passanger tire should be okay? i want to keep it close to the motor like they say just wanted to make sure it would be able to pump the oil from the filter back up into the fillercap return line and not starve the motor of oil.
Old Mar 8, 2008 | 11:01 PM
travelingman's Avatar
Amsoil filter mounting
Go on Amsoil.com click on product info you will see the bypass filters listed
when you click on it you will see instalation info . there are several illastrations an photos of different locations they can be mounted
Old Mar 8, 2008 | 11:03 PM
53 willys's Avatar
you should be fine......check out all these cummins/dodge installs on the amsoil site.....http://www.amsoil.com/bypassfilters/index.aspx
Old Mar 10, 2008 | 10:29 PM
DiEseLjunKy's Avatar
I saw where a guy on cumminsforum mounted one on his frame rail under the passenger seat area - the filters were horizontal with the ground - and fabbed up a brush shield for it. A neat clean job and he says it works fine that way but I might be a little leary of it myself.
czkid
Oct 18, 2007 07:38 PM
OH Sick
25
Feb 27, 2007 12:39 PM
underwoodtransp
Jan 1, 2006 02:34 PM
