Am I getting the right amount of boost??
Old Sep 24, 2005 | 06:16 PM
carsonhw's Avatar
i have the super phat shaft 66 turbo and im running the crazy larry and mp-8 and the highest boost i see is 40-41 WOT should i be seeing higher boost or is this normal??
Old Sep 24, 2005 | 06:29 PM
RamWheelsBy4's Avatar
What are you using for boost readings? I have Autometer 60psi Ultra-Lite. I played a little with Crazy Larry and HOT Juice/Attitude last week before the Hurricane interrupted me. With Crazy Larry and HOT Juice on level 2(60hp) I saw 45psi. CL and HOT Juice on level 3(80hp) I saw 47-48psi. With my Hot Juice turned up and EZ Level 2 or 3 I see 45-46psi.
Old Sep 24, 2005 | 06:39 PM
carsonhw's Avatar
im using the same guages as you...i cant get over 40-41 no matter how i set my boxes
Old Sep 24, 2005 | 06:41 PM
carsonhw's Avatar
my filter is very dirty maybe i can get a little more if i clean it
Old Sep 24, 2005 | 06:50 PM
Carson
Just realized who you are. I know that the Crazy Larry program on my Triple Dog seems to be different than the Crazy Larry programs on the Power Pups, dont know if this is better or worse, just different. You are probably going to see different boost readings because the MP-8 is mainly pressure and boost fooling box. Have you tried the performance program and turning up the MP-8 some??
I had to stop playing with stacks and settings because of family issues and now because of Rita. Maybe next weekend I will do some more testing of different stacks with Triple Dog downloader, HOT Juice and EZ.
Old Sep 24, 2005 | 07:33 PM
carsonhw's Avatar
hmmm so could i not be seeing my real boost #'s??..ram did michael ever take u for a ride in my truck? he told me he took somebody for a ride??
Old Sep 24, 2005 | 07:58 PM
Carson
You are seeing the correct boost numbers on the Autometer gauge. Just the combo of BDDL and MP-8 may not generate more fuel/boost request to computer. I did not see over 41psi on the HOT Juice until I stacked the EZ on high settings. I road in your truck once before he finished the trans and before the MP-8. Went to see if your TC pulls better than the one I currently have, it does. I plan on switching to one setup like yours. When I road in it he could not really get on it because of the over boost codes that would happen before the MP-8. Pulled pretty strong even then, the Crazy Larry program on the Triple Dog does not feel as strong on the low end as the Crazy Larry program on your Power Pup did. But it is all SOTP so kind of hard to tell.
dkenny
18
Mar 15, 2014 11:49 AM
spooled142
Aug 18, 2008 08:52 AM
DISTURBED
Sep 19, 2007 09:20 PM
dodad
Dec 28, 2006 03:42 PM
dodad
Dec 28, 2006 06:28 AM
