AD or FASS
Old Oct 24, 2008 | 09:33 PM
  #76
defleshed's Avatar
nobody has any experience in the bitter cold with either unit?
Old Oct 25, 2008 | 10:07 AM
  #77
Adaminak's Avatar
I'm really curious about the cold weather aspect also. My LP is on the way out and rather than have DC "fix" it, I may as well do it right. What I don't want to do is put a silicon heater on it to keep it from freezing during a chilly Fairbanks winter.
Old Oct 25, 2008 | 01:23 PM
  #78
dodgediesel's Avatar
Originally Posted by AirDog
Give us a call here at the office. 573-635-0555. I would prefer not to "compare" on the net. Things get taken the wrong ways and it becomes a pissing match. Im sure Dan would feel the same. So feel free to give us a call. Im sure Charlie would be up for a phone call.
Mr. Airdog, can your filters be crossed over to a Fleetguard on your 150 Airdog??? Only 1 of the FASS 95 series filters can be crossed over and nobody carries replacment filters in town. Would be so nice to have a Fleetguard crossover filter...
Old Oct 25, 2008 | 01:32 PM
  #79
Hvytrkmech's Avatar
If the 150 filter is the same as the 100 filter then it is Fleetguard #FF5613.
No one usually stocks them and you may have to order an entire case of 12 filters. I bought a case from my fleetguard dealer for 80 bucks with my commercial discount.
Tim
Old Oct 25, 2008 | 01:41 PM
  #80
I'm wondering about both Airdog 150 filters...
Old Oct 28, 2008 | 09:20 PM
  #81
Hellooooooooooo????
Old Oct 29, 2008 | 09:42 AM
  #83
Lowfly's Avatar
DTR Advertiser
We have a lot of customers in Alaska and to the best of my knowledge, we have not had an issue with the cold. These pumps are designed to live under a truck and they are very durable. As far as heating the fuel goes...The system does heat the fuel just from ambient heat from running the system. it is not the kind of heat you would see with say, a WVO system but it is effective for keeping the fuel nice and well....fluid...lol.
Old Oct 29, 2008 | 11:33 AM
  #84
cquestad's Avatar
Not when it sits over night in -20...
I would like to add a fuel heater to my stand alone filter head...
Old Oct 29, 2008 | 12:34 PM
  #85
10 Micron-FF5617
5 Micron-FF5587
2 Micron-FF5613
Water Separator-FS19768
Thanks man. All of those are Fleetguard numbers I take it??
Old Oct 29, 2008 | 04:56 PM
  #87
That is correct. Sorry about that. Been busy and trying to fly through everything haha!
I don't even have a Airdog 150 yet and your help is already been top notch.
I sure hope you get some more dealers in Alberta Canada as we are a very large diesel performance province.
Thanks man...
Old Oct 29, 2008 | 06:24 PM
  #88
Diesel-Dan's Avatar
Originally Posted by TriSum
Now, you stated in one of the above posts that yourself, (FASS) and AirDog accomplish your end result (removing the air and filtering the fuel), in different ways. Can you elaborate on this and explain why you feel your method is better.
Thanks for your time.
David
OK...got some time here.....truck is about as done as its going to be i guess.....
Let me first say that i don’t like these threads as they rarely accomplish anything other than bashing and nothing every good comes out of them. Do a search, this will prob be one of the 3 AD vs FASS threads you will see me on. I don’t like to get mixed up in the sales aspect of it as I am a troubleshooter for the Tech dept. BUT this one time I will do my best at giving you factual answers to your question.
Sorry Anthony….got to step some on some toes…but with all due respect
From our side….we don’t do anything that the Air Dog doesn’t do. They say we don’t take air out of the fuel at high pressure/flow conditions. I can say if our pump is returning fuel back to the tank via the units return line, its taking air/vapor out. And not too many conditions where I can see a properly setup pump where it would not be returning fuel back to the tank. All of them would have to be externally induced to cause our pump not to return fuel.
We are not going to bash them as they make a decent pump. BUT the area we feel we differ is quality of construction of our kit. We use billet T6061 alum in our pumps. Nothing is cast. It's overly strong in design. We use mandrel bends where we can and yes that cost us size point when compared to the AD. They can have that one. But honestly where we have our pump suggested to be mounted, they fit just fine with no issue. AND no…we hardly every hear of anyone damaging filters due to them being exposed. When installed properly, the 150 Series filter just barely peak out of the bottom of the bed in short bed applications…you cant see the 95 Series at all in similar applications.
Also our pumps are modular. Meaning that you can rebuild, update, or upgrade your pump without having to purchase a new one. For example, if you wanted to update your 150 GPH pump to say a 200 GPH or larger, all you would need to do is just get a new T-Block assembly. Unbolt the old t-block and bolt on the new one. That’s it. Yes, I know….they come back with more places to leak…but this is where my side of the company comes into play. I have never seen a properly installed o-ring leak except for a very few select issues.
That brings us to the next thing. We share the same building as the company that does all our machining. So if things need to be changed, designed, or tested, they are just down stairs and though a door. No red tape. Updates can be made in mins, not days. Plus they are very well respected as they have done lots of work for Lockheed Martin, the US Government and some of the local auto manufactures. They keep tight standards to make sure they keep getting large contracts.
I’m sure I could touch on some more points…and Brad would be pointing out all the stuff I missed! Haha….but I feel that I have put some substance down that has not been posted before. I figure if anything more needs to be said…ill let Brad take it from there......
Old Oct 29, 2008 | 10:51 PM
  #89
Why are the Airdog 150's quieter than the FASS 150's??? The deal breaker between the 2 pumps for me is the noise after a year or 2 of use and the availability of Fleetguard cross-reference filters. On my 01, the FASS was the ticket!!! Great performance and customer care but it was very noticable that it was there even with the noisy 24V running. Seems that the '07 kits by both are the same parts to make it work but who's quieter?? I want to keep my quiet truck quiet. I just want to put my $700.00 to the right product to keep me happy and trouble free...
Thanks to both parties for all the pros and cons without beating each other up too bad...
