5" MBRP Resonance Issue
Old Jan 22, 2007 | 12:06 AM
WUnderwood's Avatar
ahh, I see
someone also makes stacks with mufflers built into them, I didnt know if you knew that already
Old Jan 22, 2007 | 12:09 AM
D.Wiggs's Avatar
Originally Posted by WUnderwood
ahh, I see
I don't know if they do. I was planning on running the exhaust througha muffler before they turn up for the stacks. If someone does make stacks with built in mufflers I was unaware!
Old Jan 22, 2007 | 12:11 AM
Luvnacumns's Avatar
grpipes.com has stacks with muffler that can be taken out and put back in.. If i remember correctly from their web-site maybe check them out..
Shane
Old Jan 22, 2007 | 12:20 AM
D.Wiggs's Avatar
Shane
The problem is I need 6" stacks! I think the muffler will either have to be custom done, or put in before the "turn-up".
Old Jan 22, 2007 | 12:24 AM
53 willys's Avatar
Shane
Page 6
http://www.grpipes.com/catalog.pdf
Old Jan 22, 2007 | 12:26 AM
D.Wiggs's Avatar
SWEEEEEEEEEEEEEEET!
I am so on that!
Think that will affect my EGTs at all or with the size counteract any restrictions?
Old Jan 22, 2007 | 12:30 AM
Luvnacumns's Avatar
I'm thinking you won't have to worry too much with the egt's I don't see it restricting it that much...
Good luck..
Shane
Old Jan 22, 2007 | 12:32 AM
D.Wiggs's Avatar
Oh yeah! 6" Black stacks pourin' the black smoke out of the black Optimus (AKA Assault Vehicle) !! Now I just need some propane near the tips so I can blow FIRE!!!!!!!!
Old Jan 22, 2007 | 12:34 AM
Luvnacumns's Avatar
Your Killin me Smallss
Old Jan 22, 2007 | 12:39 AM
D.Wiggs's Avatar
I want to be able to scare people. You don't think that Optimus is intimidating now, do you ?!?!
Old Jan 22, 2007 | 12:42 AM
Luvnacumns's Avatar
Not even remotely.. That little thing!! I had to e-mail your garage to all my buddies and they are just flippin over that little truck!! You need to weld something to the frame so you can pretty much say that you've built that little truck from the frame up!!!!
Shane
Old Jan 22, 2007 | 12:47 AM
53 willys's Avatar
Stack that Beast!!!!
Old Jan 22, 2007 | 12:57 AM
D.Wiggs's Avatar
Just wait till I tri-turbo it!
Just Kidding...well...maybe
Old Jan 22, 2007 | 03:54 AM
PourinDiesel's Avatar
Wiggs,
I have a 5" exhaust also. When I first bought the 5" exhaust it was hellaciously LOUD! and droned really bad going down the highway.
The only thing I have found that works well is to purchase a 5" resonator from a place like www.airflowonline.com
Place the resonator as close as you can to the turbo and it will cut about 40-60% of the drone out. If you wanted it even quieter you can put 2 resonators in.
Its not truck or tranny issue...5" is just LOUD!!
Old Jan 22, 2007 | 06:12 AM
tcr's Avatar
tcr
D. Wiggs, If your exhaust is resonating a vibration type noise at low RPMs, this seems to be normal w/ 5" and 6" exhaust systems. I believe because the piping is larger, it is stiffer, causing vibes from the engine to travel down through the exhaust system. Mine is pretty bad when idling in gear, the tip wobbles at least 1/2".
