35s
Old Jul 19, 2008 | 10:53 PM
jclaflin's Avatar
35s
hey guys will 35 inch tires fit under a truck with just a 2 inch level kit
Old Jul 19, 2008 | 10:58 PM
J-man's Avatar
I think so, but not positive. i have 315/70/17's and they are just a hair under 35", but they clear fine.
06CTDforAU's Avatar
They will fit as long as you are mounting them on the stock wheels or aftermarket ones with a similiar offset/backspacing.
Old Jul 19, 2008 | 11:02 PM
snoyes's Avatar
Some guys have mounted them with no problems, other with just a little rub at full wheel deflection. You should be fine unless you decide to take the truck offroad and require repeated full wheel deflection when requiring large amounts of suspension travel...
Old Jul 20, 2008 | 09:18 AM
Hintz's Avatar
I have 315/70s w/ no lift or rub
Old Jul 20, 2008 | 09:20 AM
madhat's Avatar
Administrator/Jarhead
I have 35 12.50's, and they rub a little at full lock, but not enough to cause any problems. Just gotta be careful...
Old Jul 20, 2008 | 11:49 AM
megacabdad's Avatar
I got 315's with a 2" spacer. With the stock rims they would rub control arms at full lock. With 4.5" back spacing, all is clear. Tires stuck out a lot though with aftermarket rims. Needed flares to avoid getting pulled over.
nauitque21
17
May 12, 2005 08:50 PM
nauitque21
May 8, 2005 04:45 PM
nauitque21
May 2, 2005 09:16 PM
scarecrow
Mar 9, 2005 09:04 PM
CTDHokie
Jul 27, 2004 05:06 PM
