35" spare and mag hytec???
Old Apr 7, 2007 | 10:43 AM
Treangen's Avatar
Anyone have a mag hytec rear diff cover on a 3500 megacab 4x4 and a 315/70/17 on H2 rim for a spare?? Fit without rubbing on diff cover??
Old Apr 7, 2007 | 03:51 PM
TexasCTD's Avatar
Bump. Im curious about this myself. Thanks for the help!
Old Apr 7, 2007 | 06:22 PM
Treangen's Avatar
Opinions from the experienced??
Old Apr 11, 2009 | 01:41 AM
MyDieselStinker's Avatar
How 'bout now, any experience with this setup?
Old Apr 11, 2009 | 07:13 AM
pullin hard's Avatar
i have an 03 truck, not a mega cab, but quad, i will guess that the rear end to hitch is the same, maybe even more for the mega. anyway, i have the mag diff cover, and had a 315 mounted on factory steel rim, and it fit under my truck no problem, even with 4" MBRP exhaust.you will have to guide it up as you crank the tire up, as least i had to, i also have air lines back there running the rear lic plate for my air bags.
Old Apr 14, 2009 | 11:06 AM
TurboTurd777's Avatar
yes it does work, i have a 06 quad with a 35 mounted on the steel rim mounted under the truck no prob with a mag tec diff cover. its very close and you have to guide it up while someone else cranks it. its a two person job in my eyes but it fits
Old Apr 14, 2009 | 06:28 PM
CD in NM's Avatar
I have a BFG 315 mounted on the stock rim up in the tire bay, made sure I kept it toward the bumpers as tight as I could get it. Clearance is just fine, close, but clears. I used a bungee at first, now I use one of those cranking tie down straps, just a little better than the bungee in my opinion.
CD
PEAKSTRYDE
Oct 11, 2007 04:20 PM
hognutz
Jun 21, 2006 11:56 PM
slavely
Mar 30, 2006 06:07 AM
lucey
Jan 31, 2005 11:38 PM
Commatoze
Apr 2, 2003 12:53 PM
