20in wheels no lift any pics??
Old Apr 22, 2009 | 06:55 PM
Hetdiesel's Avatar
Question 20in wheels no lift any pics??
im looking into buying wheels and tires and like the 20 and 19inch wheels but how big of a tire can you get with no lift? does anyone have pics???
Old Apr 22, 2009 | 07:01 PM
jonny mopar's Avatar
you can clear 33"s easy. but also depends on the offset of the wheel. i have 36"s on 20's with a 6" lift and the rub my mud flaps on hard turns because of the off set.
Old Apr 23, 2009 | 01:34 AM
ram4tow's Avatar
i have in my profile a pic of my truck before i leveled the front.. it had 20x9 (not sure of the offset right now) rims with 35x12.5-20 toyo m/ts on .. they rubbed the control arms at full lock and occasionally rubbed on the mud flaps.. id put a leveling kit on if you plan on going with a tire bigger then 33" it can be done with 35's with some rub tho..
Old Apr 23, 2009 | 06:23 AM
MorganMech's Avatar
I am running 20x10's in 33's on mine. Did the front leveling kit. Do have rub issues. Need to be careful on the backspacing. Also, wouldnt recommend Nitto Terra Grapplers if you plan on leaving the pavement!!
Old Apr 23, 2009 | 04:32 PM
Wcsting's Avatar
20x10s with 2" level kit and 35' BFG's
Old Apr 23, 2009 | 06:43 PM
RDRASH's Avatar
20x8.5 33's no rubbing stock height
Old Apr 23, 2009 | 07:45 PM
mpracehemi's Avatar
These are moto metals 20x9 with like a 4'' b.s. and I didn't do a level kit. I trimmed the inner fender as well as cut and re-spot welded the inner body seams for clearance on my 2wd. The tires are 32'' nitto's terra grapplers 285/55r. The tires really grip as for traction. You don't have info. as to what your truck is, but here's some info anyway.
SmokenRam
Aug 2, 2008 05:47 PM
rynemurch
Feb 12, 2008 01:54 AM
blh1972
May 10, 2007 09:04 AM
tontof18
Sep 28, 2006 07:59 PM
