2006 Dodge Tach issues
Old Jul 9, 2014 | 01:14 PM
OMGDODGE's Avatar
does the misreading tach have an effect on the turbo waste gate or turbo in general? as this is all computer control.
Old Jul 9, 2014 | 03:29 PM
BigIron70's Avatar
Cummins Guru
Only if setting a code, perform cluster test, key on while holding odometer reset in. Watch movement of tach needle should swing 5-3-1. if not then replace cluster.
Old Jul 9, 2014 | 06:32 PM
ColinP's Avatar
There is a cheap fix out there for the '06 tachs that involves just removing a few torx screws from the perimeter if the back of the cluster. Do a search, several people have had good results. I ended up replacing the entire cluster before I was aware of the cheap fix.
Old Jul 13, 2014 | 12:26 PM
OMGDODGE's Avatar
Thx! Tach is an issue just typical of what you get for your tens of thousands of dollars these days!
Old Jul 13, 2014 | 12:49 PM
mykaos's Avatar
Oh, that and a nav / sat radio that loves to "crash". But rest assured, the problem wasn't confined to just us. My fiance's '12 Avenger shares the joy . (Love the car otherwise )
Old Jul 20, 2014 | 11:18 PM
mwheaty's Avatar
https://www.dieseltruckresource.com/...x-t311818.html
i did the fix, helped for about 3 months, then stopped working again, only works now when cruising on the highway, in town doesn't work worth a ****
good luck
Old Aug 2, 2014 | 10:38 AM
GhettoVaquero's Avatar
I replaced the sensor (dealer item, $26) on mine and it worked for all of a week. I idle at zero again. Could it be the tach itself?
Old Aug 2, 2014 | 10:56 AM
rockcrawler304's Avatar
Have you tried the 30 minute fix?
I'm 99% sure it is not the tach.
Old Aug 7, 2014 | 09:05 AM
This wizardry worked! Thank you!!!!!!!!
Old Aug 7, 2014 | 02:09 PM
KWKING's Avatar
The real issue is most likely cold solder joints or cracked circuit board lands on the instrument cluster
Removing screws takes tension or flexing out of the picture and improves the poor connection so that in most cases the tach now works
But thats not the proper fix, something else is wrong. Still saves money if it works but if I were to remove my cluster I would be looking a little deeper.
Old Aug 7, 2014 | 08:54 PM
Glad it worked!!
Old Aug 24, 2020 | 02:25 PM
toomanytrucks's Avatar
Smile 30 minute fix update from OP
Hello everyone it's been awhile since I've logged back in but my original fix on my 06 tach is still working and not once has the tach messed up since 2014! "Knock on WOOD"
Old May 28, 2023 | 08:18 AM
usmilret's Avatar
I know that it has been some time since this thread was active like coming up on three years. The issue is important enough to update. Remove the dash cluster and set it on a bench. Remove the backing to where you can access the cold welds on the back. Retouch those cold welds with a soldering gun and reassemble. There is some shimming that needs to be done when reassembling and when all is back together your RPM gauge should be working. There are many examples of just what I described on youtube. This worked out perfectly for me.
2006 Dodge Ram 2500 5.9.
Old Jun 2, 2023 | 08:02 AM
haily grace's Avatar
Did you get any codes when it happened ?
Old Feb 29, 2024 | 04:09 PM
usmilret's Avatar
There are youtube videos on repairing the dash gauge assembly. It worked for me. The dash gauge assembly went through a cold soldiering assembling process that was substandard and defective. Remove the dash gauge, flip it ver and re soldier the joints. Place a couple of shims on the back side of the dash and your RPM is repaired.
