1-2 shift problems
1-2 shift problems
After breaking my front band I decided to upgrade tranny to hts heavy duty band and there race clutch kit.After rebuild I now have a really light shift from 1st to 2nd and under light to medium throttle it goes directly into 3rd.I also changed the shift lever from stock 5.0 to 4.3.Do you guys think the lever change could be my problem?Before the change I had no problem smoking the tires on 1-2 shift now I can't spin on a wet road.Even with the tq converter lockup switch on you can hardly feel 1-2 shift.After shifting into2nd there's no slipping.
My valve body and converter is a dunrite.Before the band break no shifting issues at all.
Call tony at dunrite he is knowledgable and im sure he can help you get this problem lined out. Is this a valve body built by dunrite or is this a transbuddy kit if so you may not have set it right just checking all the possibilities.
itr.#1446
Nov 9, 2008 09:03 PM
MoparRiggan
29
Nov 9, 2008 12:02 AM
CASMOKIN
Competition / Pulls / OffRoad
Dec 30, 2005 01:28 PM
