Visteon to Sanden A/C Compressor Upgrade?
Old Jun 3, 2014 | 09:06 PM
Tobin's Avatar
Anyone change the '06-up Visteon A/C compressor to a Sanden compressor used in the '05-earlier models? It seems like the Sanden is a better compressor and holds up better. Having bad luck with dealer supplied compressors, about to swap in a rebuilt compressor from a local guy we deal with.
Original compressor was leaking out the front seal. Replaced at ~120k miles with a compressor from the dealer. That one lasted about 1000 miles, the front seal took a dump. The parts guy said that was a common problem with that revision and I got the next revision. That one worked great for about 12k miles and it started leaking oil between the two halves.
Tobin
Old Jun 3, 2014 | 10:07 PM
HMX-1's Avatar
Sanden's are being used for engine driven air compressors; I know since I have one on my '08.
I'd say go ahead and do it.
-Kris
Old Jun 9, 2014 | 05:34 AM
Frosty46's Avatar
Did a replacement with the Sanden unit once and had good luck. Kept that truck for two years after and no failures. Watch alignment as it is critical--good straight edge tells the tale.
MARF75
Sep 3, 2014 05:52 AM
flyboy129
Aug 25, 2014 08:44 PM
jimbo486
Oct 17, 2011 05:56 PM
jimbo486
Aug 28, 2011 10:46 PM
gadget.35-06
Jun 2, 2011 01:54 PM
