vibration
Old Jan 18, 2011 | 09:48 AM
seldomseen's Avatar
vibration
I have a vibration that is most noticed when driving between 70-76 mph, also when accelerating, it seems to happen most when cruise control is putting power on, is this a u-joint going out truck has 44000 miles about 20000 towing. I u-joint mwhat is the best replacment. Thanks
Old Jan 21, 2011 | 09:41 AM
seldomseen's Avatar
can somebody tell me if I am on the right track or not? What could be other causes for this vibration?
Old Jan 21, 2011 | 09:50 AM
Chris Taylor's Avatar
In my experience a ujoint will vib at slower speeds and go away at higher from the centrifugal force of the rotation. Not a bad place to start though. Get under the truck and see if there is any slop in the joints by hand.
Old Jan 21, 2011 | 09:56 AM
klx650a2's Avatar
I had a high speed vibration as well. Ended up being the drive shaft needed to be balanced.
I've also replaced u-joints too that were causing low speed vibration.
Old Jan 21, 2011 | 10:04 AM
Beast2B's Avatar
under acceleration the rear end pinion rises. i got some vibration on my 01 under acceleration at lower speeds and it turned out to be the rear u-joint. spring wrap with lots of torque...
Old Jan 21, 2011 | 01:17 PM
buckied's Avatar
Check out the post I put up yesterday in this forum in this same forum about a truck we went to look at I think the title of the post was Lookin at a new (to me) truck... If your's is an auto look at what I described and what the dealer mechanic diagnosed it as
dodgedsl03
Jan 18, 2007 10:08 PM
Davidp
Mar 19, 2003 11:29 PM
spitzair
Mar 11, 2003 11:06 PM
deere nut
Dec 1, 2002 08:09 AM
chdiesel
Nov 3, 2002 04:39 PM
