Turbo system
Old Apr 25, 2019 | 09:30 PM
James D Smith's Avatar
Turbo system
I have a 2003 Bluebird Skoolie 5.9 Cummins / Allison 545 conversion that I use for living in on road jobs. Today as I was coming up to Farmington from Albuquerque. On an uphill grade I heard a "pop" and then an air leak. My air brake system is good, it only hisses when the engine is under load. Down hill it is barely noticeable. When I stopped to check it, the filter clog indicator had come apart so I put a cap on it until I can get a replacement. The leak is still active... I checked the pressure side of the turbo for a bad relief valve but couldn't find any. When Vehicles pass me on the left I can hear a pft pft pft kind of noise reflecting off the cars... It is definitely an air leak, has to be associated with the turbo because it changes with load on the engine. Everything seems to be running ok... Any ideas here?
Old Apr 26, 2019 | 08:04 AM
FMB's Avatar
FMB
Originally Posted by James D Smith
On an uphill grade I heard a "pop" and then an air leak. . . . only hisses when the engine is under load.
Sounds like you had a turbo duct failure either from the turbo to the intercooler or intercooler to the intake manifold. Check these carefully as the blowout could hide.
Back to morning brew . . .
Old Apr 26, 2019 | 08:30 AM
That's what I was thinking... I checked initially and didn't see anything... I'll take off the expansion joints and the ducts and check more carefully. Thanks, Jimmy
Old Nov 11, 2019 | 04:49 PM
Turbo duct
It turned out to be the suction hose on the Air Compressor.
daddy mopar
Jan 22, 2009 05:26 PM
rbox
Nov 11, 2008 03:12 PM
lowwag64
Jun 11, 2007 03:07 PM
running4bhs
Jul 9, 2005 05:15 AM
Rob1325
Feb 7, 2004 09:43 PM
