Surging- cant figure it out.
Old Nov 7, 2008 | 04:54 PM
misfitfeind's Avatar
First time post here, I've been a lurker for a while now and any questions I've had I would search for about 2mins, and I find the answer, untill now.
When I take off slowly only, After the truck shifts into second it surges for a couple seconds. And If I am not accelerating it will keep bucking and surging. First thing I thought was fuel delivery. But the truck is close to stock. The only mods are afe intake and a Geno's delete pipe. I didnt think the mods would cause the surging. I have'nt worried to much about it cause when you accelerate under normal conditions it does'nt surge or buck at all.
Old Nov 7, 2008 | 04:58 PM
Whoops wrong forum
Old Nov 8, 2008 | 06:01 AM
Dodgezilla's Avatar
Are you sure it's not "Shuttle shifting" which is where the trans can't make up it's mind if it wants to be in 2nd or 3rd gear so it keeps going back and forth between the two? It is a very common problem with the 48re trans....
Old Nov 8, 2008 | 07:48 AM
yeah the truck is doing the 1-2-1 tanny hunting, as its called on here, going to the dealer today to get the trans serviced and and the solenoid replaced. As long as its under warranty
Old Nov 8, 2008 | 08:22 AM
Dodgezilla's Avatar
Should be unless you have too many miles on it...
Old Nov 9, 2008 | 05:24 PM
caper11's Avatar
My truck does this from time to time, mostly when there is hardly and pressure on the acclerator, Is this something I should be concerned with.
Dlowkes7
May 25, 2011 05:44 PM
misfitfeind
Nov 7, 2008 07:12 PM
fullbore farmer
Oct 10, 2008 07:57 AM
92cummisw350le
Oct 5, 2007 09:18 PM
luke h
Jan 10, 2005 02:53 PM
