Problems with 2007.5 6.7
Old Jun 18, 2012 | 09:38 AM
Southern Pride's Avatar
The company i work for, has a 07.5 dodge. we replaced the egr actuator back in january. i just took it back in last week because it was throwing codes and defueling again. the dealer said the fuel pressure relief valve was bad and needed replacement. the dpf was also "80%" full. they said that since that relieft valve wasnt working properly the truck has not been able to regen in a long while and thats why the dpf was full. has anyone had problems with the relief valve? im new to the newer 6.7's. the truck is out of warranty now and has just 102,000 miles and some change on it. i use the truck for pulling our equipment, so the truck has as little as 14,000lbs (kubota 121-3 mini-ex) behind it every day to the occasional 20,000 when i pull the backhoe. i had thought that if these trucks were worked hard that the dpf wouldnt get clogged up as much since the engine's working harder? im just looking for some advice. thanks
Old Jun 18, 2012 | 11:02 AM
klx650a2's Avatar
If you're towing all the time, the dpf should be ok, unless you are mostly intown, then things will plug up regardless. Idling is especially hard on the emissions system. If you can swing it, do the minimal deletes and the truck will be 10 times better.
Old Jun 20, 2012 | 12:52 PM
Blake Clark's Avatar
The relief valves usually only have issues on trucks that are running increased rail pressures. Havent heard of any issues on a stock truck with them. Thats not to say its not possible though.
I agree with klx. If you are not DOT reg, delete that sucker and drive happy, and save the company a couple of dimes with the increased fuel milage. Just mind the right foot, the tranny will thank you.
Old Jul 1, 2012 | 07:19 PM
thanks guys. the truck is completely stock. i was hauling hay two days ago, and the truck did the same limp mode again. and the truck is registered dot, but here in tx theres no exhaust or emission testing going on, at least for now.
Old Jul 28, 2012 | 07:41 PM
dcwolfe85's Avatar
6.7 auto transmission
What transmission does the 2008 dodge 2500 have...my truck has 60k miles and the transmission is already giving out...wud like to have an allison but i dont know if thats even possible. I guess id just like to know if there is a better tranny to have put n this truck
Old Jul 28, 2012 | 11:05 PM
RamGazer's Avatar
10 Year Member
To get off topic, I sure am happy I traded in my 2007.5 6.7 4x4 in for a 2006 5.9 2x4! No more EGR or clogged filters or going into limp mode to worry about!
Fronty Owner
Nov 17, 2007 12:44 PM
burners_banshee
Sep 10, 2007 02:03 PM
ID2500Ram
Apr 29, 2007 11:31 PM
