power reduced mode question
Old Mar 25, 2009 | 08:36 PM
hwebb's Avatar
ive had my truck straight piped since the middle of football season and has thrown the codes and been in power reduced mode ever since is this a bad thing or should i get it out of it somehow?
Old Mar 25, 2009 | 09:38 PM
ChrisM55's Avatar
Well, you are paying for a truck with half the horses it should have, I would say there is a problem!!
If you are going to monkey with the exhaust you need to get a fooler kit from H&S or BADP to manke the truck run right.
Old Mar 29, 2009 | 08:51 PM
hwebb's Avatar
i thought about gettin the edge juice with attitude would it be able to clear those codes and fix the problem?
thanks
Old Mar 29, 2009 | 09:12 PM
ChrisM55's Avatar
it will only help some stuff but because you are in limp mode you are more than likely going to have to put it back to stock take it in to the dealer get it reflashed and then do a proper delete kit. The H&S kit is only about 650.00 for the turbo back and will at least let you run right. The kit is not code free but will keep it out of limp mode. You add the Edge and then it clears the codes at startup (soft codes not the ones that put it in limp) and then it lets hre run without the MIL
chris
Old Apr 2, 2009 | 05:42 PM
hwebb's Avatar
im in really good with the dealer is there anything they could do that you know of to eliminate this?
aketay
Sep 23, 2012 08:35 PM
iweb
Jun 26, 2005 11:49 PM
