Mounting Brake Controller
Old Jan 1, 2011 | 09:57 PM
jerryleejr's Avatar
Just mounted my Prodigy, However when I have time I would like to recess it a little more. Has anyone had that part of the console off? What is directly behind the plastic? I know there is a metal piece that runs up on both sides but does it also go across? I just plan on removing enough to maybe slide my controller back about 2-3" Just wouldnt want to start cutting into it to find something else blocking me.
JJ
Old Jan 1, 2011 | 10:39 PM
rockcrawler304's Avatar
I remember seeing some pictures on here of one removed and I think you are fine. I'm sure someone else will chime in with better info.
Old Jan 2, 2011 | 12:25 AM
ram 2500's Avatar
It is just an open space behind, my uncle mounted a cb in that same spot.
Old Jan 2, 2011 | 05:57 PM
jerryleejr's Avatar
Can that piece be removed by itself? The lip all the way around suggests it can be.
JJ
Old Jan 2, 2011 | 09:05 PM
ram 2500's Avatar
Yes it removes by it's self, on the mega cabs there is a piece of pipe that runs flat on the floor behind it for the rear heat/ac
Old Jan 2, 2011 | 10:24 PM
jerryleejr's Avatar
So I guess this begs the question so I dont break it, is it just held in by clips? and will a flat tip suffice or Do I need a special tool?
Old Jan 2, 2011 | 11:06 PM
VictorC's Avatar
on my 07 QC, you first need to remove the center console on the floor. There are a few screws holding that piece which are covered by the console. Do a search for any installation instructions on a head unit because they have to get that same piece off before the head unit. each piece reveals screws for he next piece, etc.
Old Jan 3, 2011 | 07:00 AM
jerryleejr's Avatar
Thanks guys I'll try to tackle it and post pics when I'm done.
JJ
Old Jan 3, 2011 | 03:26 PM
mega-engr's Avatar
"California Style"
Yes, remove the center console first as I think there are some screws behind it on the bottom. That is where I mounted my prodigy and I just cut a rectangular slot for the connector to clear and still have the "mount" flush to the rear of the panel.
Old Jan 3, 2011 | 04:25 PM
jerryleejr's Avatar
Well it's in again, don't like the angle I needed to clear the gear shift but it allowed me to keep my Sirius radio.
JJ
Old Jan 3, 2011 | 05:37 PM
mega-engr's Avatar
"California Style"
I have mine where your radio is and before that I simply had it velcroed up to the right side of the panel below the steering column. Isn't that a bit far away? I like to use the manual from time to time...
Old Jan 3, 2011 | 07:13 PM
jerryleejr's Avatar
I Originally had it where the Radio was but was unable to find a suitable place to put the radio. As for to far away I seem to be able to reach it ok, I just did a 600 mile trip and really had no reason to touch it with about an 8000 pound load.
JJ
Old Jan 18, 2011 | 03:53 PM
Bill1374's Avatar
I'm with mega on this one. Mine's an auto 4x so the Prodigy comes just over the top of the 4x shifter. Been several times over the years where I wanted all the trailer brake I could get or wanted just the trailer brake. Always mounted the controller where I could reach it easily.
RHC
Oct 22, 2003 07:30 AM
NC_Mog
Jul 1, 2003 11:34 AM
atc250r
Mar 22, 2003 12:27 PM
misterKTM
Jan 11, 2003 07:55 PM
