Help head gasket
Old Jan 20, 2013 | 07:52 PM
256tylerw's Avatar
Help head gasket
My 08 megacab just started blowing coolant out the overflow but my truck has never ran hot
It is deleted and I run the h and s on mild is it possible to just retorque the head or if I pull the head what head gasket do I need to run and should I get the head studs or just factory bolts. I rarely pull anything and if so nothing heavy just need a truck sometimes and this gets good mpg. What route do I need to take with this. Thanks in advance it has 130k on it
Old Jan 20, 2013 | 08:39 PM
06RAM2500's Avatar
Once she starts to leak, really is no other fix than replacing the gasket. This go around, install head studs.
Old Jan 20, 2013 | 08:46 PM
256tylerw's Avatar
Gasket
Is there a better head gasket than the factory one
Old Feb 8, 2013 | 02:34 PM
tacdaddy's Avatar
I just had the same happen. I wasnt paying attention and got into the ped. When I got home I had coolant blowing out of the over flow. From everything I read it sounded like a HG. I am running and XRT Pro on hot. With all that I have done to the truck I new I was playing with fire by not doing head studs.
Took it to Centex Diesel around Canyon Lane, Tx. Cody the manager is good. They tested the truck and said that the HG was not totally gone and said that he recomened new HG and A1 HII head studs. They are doing the work as I type. Seem like good guys.
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
