Engine Temps
Engine Temps
My truck has no mods and I'm not towing, 180k miles. It used to run 200-210 all the time, now it seems to fluctuate 180~210, but on a trip with some hills leaving Phoenix, it ran up to 230 and started jumping higher then lower... I downshifted to keep the RPMs up, but hills are definitely affecting the temp (in a scary way). Also noticed engine was not responsive, power was low. Any ideas fellas? I had a CEL later in the trip, haven't checked it yet.
Thanks
Thanks
Usually, in the interest of keeping my vehicles reliable, I will throw in a new thermostat when I have the cooling system apart, like to replace the coolant, as it isn't a lifetime part. If yours is original, it's probably worth replacing it, hopefully it improves the condition. I would also take the hose and clean all the grime from the fins of the radiator.
Picked up a thermostat today. On my way home, the temps dropped well below 170 when going downhill, looks like it's probably stuck partially open. I will update when I get it switched out. Thanks for the advice!!!
Dan
Dan
rico334
Oct 27, 2004 06:49 PM
...Ben
