Engine Light/No Fuse
Old Jul 14, 2008 | 07:47 AM
boatman22's Avatar
Engine light came on about 3 weeks ago. Truck still runs great, no problems. I noticed yesterday that when I first start it, in the odometer window it says "no fuse" then goes back to to odometer reading. Any clues to what this means?
Old Jul 16, 2008 | 09:27 PM
titoheadfaceman's Avatar
look in the TIPM and make sure the IOD fuse is fully pushed in. It will have a little plastic cover deal over it. Just push the whole thing down and that will probably fix your problem
Old Jul 28, 2008 | 07:04 AM
boatman22's Avatar
Thanks for the info...when I get back home I'll check it out and let everyone know if it fixes the problem.
Old Jul 31, 2008 | 12:50 PM
boatman22's Avatar
Got home last evening and just now went to check. The fuse on #11 was blown. It had a white cap over it. I'm on the way for a fuse now, and will update later
Old Jul 31, 2008 | 01:22 PM
boatman22's Avatar
The fuse fixed the problem. Alarm and locks now work. the engine light did not go off. I had the parts store put a scanner on it and there were no codes. I will drive for a while and see if the engine light goes out.
Old Jul 31, 2008 | 01:43 PM
Pull Ya's Avatar
Maybe it's that junk your pulling. You need better props!!!
Jay
bigjohn92
Nov 25, 2010 01:32 PM
shellman
Dec 14, 2005 08:06 PM
Evildiesel
Nov 18, 2005 04:12 PM
TerryS
Sep 18, 2005 03:33 PM
DEC
Nov 6, 2003 06:48 PM
