egr help now
Old Mar 18, 2009 | 08:19 PM
TheMighty'67's Avatar
egr help now
i just unplugged my egr and it started loaping real bad, i tried to drive it and it poured smoke and shuttered bad. All i unplugged was the one plug up top on the valve itself, any help would be awsome
thanks,
Dayton
Old Mar 18, 2009 | 09:23 PM
bob4x4's Avatar
Plug it back in
Old Mar 18, 2009 | 10:15 PM
jeff-kc9ftp's Avatar
butterfly closed?
On some, depending on flash version. the electronic throttle butterfly plate will default in the closed position, choking off the intake air. You'll either have to remove the plate or update the ecm.
Mine would do the surge, stumble thing only at startup once in a while. I ended up removing the butterfly.
jeff
Old Mar 19, 2009 | 07:13 AM
Jim W's Avatar
Did you un-plugged the correct one? Another user on one of these forums un-plugged the incorrect one and his acted similar to yours. I woukd do a search on this forumlooking for un-plugging the EGE and deletes. I believe there was instructions and pictures show the step by steps needed to remove the ERG vavle along with un-plugging the EGR. I also believe the writer stated you needed to have the latest flash for your model year.
Hope this helps. $0.02
Old Apr 1, 2009 | 08:50 AM
ShibbyEng.'s Avatar
Some have found that you need the behavior of the truck is largely dependent on the flash present. Has your truck been upgraded to the latest flash?
camshaft01
15
Jun 9, 2015 03:43 PM
WaFLHTRider
Jun 13, 2011 05:29 PM
Black98LS1
19
Dec 13, 2009 09:32 AM
MOJO1
Aug 4, 2009 06:28 PM
