DPF Problems - are they gone?
Old Oct 6, 2007 | 04:57 AM
myfirsttruck's Avatar
Haven' theard from anyone regarding new DPF problems - have the flashes fixed the problem?All the problems I had with one of my company C&C's ended up being driver related! -wrong fuel, oil, using additives and not changing the fuel filter
Old Oct 6, 2007 | 08:17 AM
GrandpasRam's Avatar
So far I have 3500 miles on mine, and only had two flashes and on EGR sensor replaced. Last 2000 miles hav had zero problems of any kind.
Old Oct 6, 2007 | 08:19 AM
sabersix's Avatar
I've had no DPF problems in 5800 miles. I did get a new turbo. The truck has had both AT and AU flashes.
Are the problems fixed? I don't think anyone can tell you. Only time will tell. Personally, I have no regrets about buying my 6.7L.
Old Oct 6, 2007 | 08:46 AM
2rowdy's Avatar
I have 15000 miles on mine. Never had a dpf prob. Looks going to get third egr cooler valve replaced cel came on again at about 11:30 last night. Code p245a. So they are going to install new one and cut hole in my soundproofing where it is hitting.
Old Oct 6, 2007 | 09:13 AM
sleds's Avatar
Had mine since 1st of may and no problems, no codes and no flashes.
Old Oct 6, 2007 | 10:10 AM
n0ne's Avatar
just over 12000 on mine and i've only had the flashes done.. No problems what so ever.. I know i have a cracked DPF tho... but its not bad enuff to throw codes yet.. So i'll leave it cracked.. i like being able to see smoke
Old Oct 6, 2007 | 10:48 AM
fflarry's Avatar
Correct fuel since new and no problems with mine. AT & AU flashes seem to have stopped the EGR codes. Just over 8000 miles.
Old Oct 6, 2007 | 11:53 AM
I have 22,000 miles on mine and no problems! I do have both the AT and had the AU put in on Tuesday for the P245A code.
Old Oct 6, 2007 | 11:57 AM
wreedCTD's Avatar
I think the new software has really helped.
Old Oct 6, 2007 | 01:37 PM
Outwest's Avatar
I had the truck flashed once at about 9,000 miles (can't remember the code) but it was not a problem with the DPF. I have 15,000 miles on the truck now. Almost all of those mile have been at highway speeds though.
Old Oct 8, 2007 | 02:35 AM
Bigwhitey3500's Avatar
6300 miles. Had the dealer flash the AT update before taking delivery. Had a CEL come on at around 5000 miles for a couple days then it went off. Never did get the code. Otherwise no issues.
Old Oct 8, 2007 | 08:49 AM
cadent47's Avatar
I've had mine since March, 6,500 miles, no problems or flashes, so far. Most of my miles are highway or towing on the highway.
Old Oct 8, 2007 | 11:57 AM
Dusty Ratcliff's Avatar
a little over 22,000miles on mine with no flashes, no trips to the dealer, just regular oil & filter changes, & lots of loaded miles, so far no CEL's or any DPF problems, only complaint is a slight hesitation type feeling with the cruise set & going downhill, smooth as silk if the motor is under acceleration, but take away the load & it can't seem to smooth out, like the throttle is engaging & then dis-engaging very slightly????? but nothing the Smarty won't fix I hope!! so far so good! love the 6.7L engine! Dusty
Old Oct 8, 2007 | 12:08 PM
zxa's Avatar
zxa
15.000k on our truck....no problem except the famous p245 sometime...any issue with the dpf!! running ulsd naturally.......
Old Oct 9, 2007 | 02:05 AM
My-1st-diesel's Avatar
I have had a Cummins Data logger in my truck for the last three weeks. I spoke with the engineer today and it appears that the new AU firmware has made a major improvement with the emission problems. I have had P1451and P2463 multiple times and P245A once with the data logger. The engineer assured me that there was nothing wrong with my truck. The error codes were being thrown due to different driving conditions.
We have all heard that it is recommended to drive on the highway for 45 minutes -- this is only one of many ways for the truck to "de-soot" -- and the preferred method for guaranting the process completes. In my case I coast down a long grade every day during my commute, I would get 70% full messages daily and about every fifth day a CEL. The error codes were being thrown due to it not being able to complete the de-soot process not because anything was clogged. The new firmware seems to have corrected this problem, I no longer get the 70% full messages and of course no CEL's.
The engineer would tell me to much about the new algorythm in the firmware but I am guessing that they are performing the desoot process more often for shorter periods of time and monitoring the the amount of fuel being consumed not just RPM's.
