Differential oil looked like milk
Old Feb 6, 2020 | 04:32 AM
Justin Tingley's Avatar
I have a 2018 Ram 3500 that had the same issue. The dealer said it was fine so I inspected it myself and I also pressure tested it. This is what I found.
Notice the tiny seam where the nut touches the plate? its a paper thin gap.
Notice that the nut is just tacked on? Not an issue at all as long as your rubber washer is doing its job. When I pressure tested this I found out that there was blow by around the nut and my rubber washer was failing on one side. I replaced the washer with a larger one and I have had zero issues since. Not saying that this is the same issue fix for you but it worked for me. It took me a while to figure it out because logically I checked my axle/bearing and seals first, second my vent when I found nothing I did the pressure test. In order to do the pressure test I used a flat piece of 1/8" sheet metal and gasket maker to fasten and seal the diff cover. Then I welded an air nipple for a compressor hose to the back. After it cured I filled it with a light 5W30 engine oil for the test(because its cheap lol).
isu elvi
29
Jun 2, 2010 08:20 AM
dieselbeef
Apr 10, 2008 04:49 PM
iker42
Feb 5, 2007 03:35 PM
Jezzhuntin
Sep 7, 2006 01:37 PM
westcoaster
Sep 1, 2003 01:32 PM
