The difference between a 2500 and a 3500
Old Nov 24, 2008 | 04:23 PM
Hounddog's Avatar
Same transfer case and rear axle.No difference.
Old Nov 24, 2008 | 04:27 PM
MikeRP's Avatar
Originally Posted by MegaCabRam
not sure if i can come up with 5 but i pretty sure the 3500's have a heavier duty transfer case and rear end...
Transfer case and rear end are exactly the same on a 2008.
Old Nov 24, 2008 | 04:28 PM
MikeRP's Avatar
Oops sorry Hounddog.
Old Nov 24, 2008 | 04:40 PM
MegaCabRam's Avatar
ok didnt know, i do know for a fact they were differnt in 2nd gens, atleast thats what iv been told i could be wrong again
Old Nov 24, 2008 | 04:57 PM
Hounddog's Avatar
2nd Gens the transfer case was the same.The rear axles(Dana) had some differences and varied from year models. Oh and 4.10 gears PULL more weight easier then 3.73s.Theres a REASON 4.10s are a option.NO fooling.
Old Nov 24, 2008 | 05:15 PM
MikeRP's Avatar
Hounddog:
I agree 4.10's will pull heavy better. I just think with the new 6 speed selectable auto tranny and these high torque CTD's this advantage is more limited within the say below 13000 lb weight category. However, as you go above 13000 lbs and past 16000 lbs, as some purport to do. I'd say that's where the 4.10's make a difference as you indicate.
I guess really the only way to tell is drive two identical trucks side by side heavy which I haven't done with the 4.10's and the 3.73's.
Mike
Old Nov 24, 2008 | 05:27 PM
browndg's Avatar
I just made the gear swap about 2-weeks ago,from 373 to 4;10'S.
The difference for me is hwy speeds, I was able to cruise around 77 mph and stay under 2k(RPM)
Now with the 4:10's I can cruise right at 70 and stay under the 2K.
Made a big difference pulling my 14,000 toy hauler up a twisty incline.
Old Nov 24, 2008 | 05:56 PM
coolbreeze's Avatar
What engine browndg?
Old Nov 24, 2008 | 06:03 PM
browndg's Avatar
Sorry about that, 5.9
Old Nov 24, 2008 | 06:04 PM
bbturbo's Avatar
Up here in BC we have a luxury tax on vehicles. My 3500 (and everybody else's around here) does not qualify as a luxury vehicle (high GVW), however 2500's do. The tax is something like 17% on the MSRP if you are over I think 43000. Can't dredge up the numbers right now. But there were many good reasons for me to get the 1 ton, none were mechanical.
After some checking, our threshold for charging luxury tax now stands at 55000$. You would be paying 3% luxury tax, 5% Goods and Services Tax, and 7% Provincial Sales Tax. So buying the higher GVW vehicle you'd save $1650.
Old Nov 24, 2008 | 07:03 PM
MikeRP's Avatar
I guess what I was thinking, and thinking may be a problem for me, with the six speed you would just manually go to 5th.
I'd guess right now I'm pretty close to the same value at 77 mph - just under 2000 rpm with the 6 speed tranny.
At 70 mph - I'd probably use 5th gear and get the same result. - just under 2000 rpm. So the 6 speed gives you some more flexibility.
However, I wonder what the 5.9 with a 48rfe in first gear tach's at 10 mph? Then we could compare the 6 speed in first at the same mph.
Old Nov 24, 2008 | 09:48 PM
DieselLady's Avatar
Well if you have to have 4.10 gears and you can only find the 3.73s. My brother has an 06 with standard trans and 4.10s and he really want's to change to 3.73s. So I KNOW he will be willing to swap with you at a moments notice. He lives in the Kansas area but drives all over the US so could work out the contact stuff too. Just an FYI.
He says the truck will pull tree stumps but forget going any faster than 55 on the highway or your fuel economy goes in the toilet.
Old Nov 24, 2008 | 11:56 PM
DJENSEN9367's Avatar
I have an 08 with 4.10, always have a trailer on the back, perfect combo,especially on the hills, 3.73 is ok in florida but go across country once and you will love the 4.10. With the 6 speed auto, the 4.10 is king ecxept for grocery getters, I also had an 06 with chips etc, no comparison, do not need to chip this one, can't keep rear tires on it and i am an old guy who does not hot rod (except fORDS on a grade), if you don't tow buy a honda.
Old Nov 25, 2008 | 12:39 AM
snoyes's Avatar
2006 G-56 manual transmission only came with 3.73s... not 4.10s. 4.10s were options only with the autos.
Old Nov 25, 2008 | 07:13 AM
MikeRP's Avatar
Guess I must be a grocery getter
