Coolent leak from side of engine
Old Apr 21, 2012 | 06:38 PM
etoy's Avatar
Hello I have a 2008 6.7L and it just started to leak coolent (lot of drips, almost a steady stream can be seen from below) from the front right corner of the engine. There is a casting that bolts to the side of the engine that the radiator hose connects to along with a hose from the EGR cooler - it might be coming from behind that. It is too hard to tell for sure if that is the source or if it is running down from someplace else, has anyone seen this? The source might be the wet area in the picture Coolent leak from side of engine-p4210047.jpg
Old Apr 22, 2012 | 09:25 AM
Dr.Dizzle's Avatar
Could be bleeding from the weep hole on the water pump. If it is...replace the water pump.
91.5CTDBanks
Aug 26, 2008 06:45 PM
Buffman88
Mar 18, 2007 01:02 PM
DuaneWKKC
Sep 25, 2005 04:02 PM
thumbs
Oct 1, 2004 04:53 PM
thumbs
Jun 12, 2003 12:18 PM
