confusing fault code
Old Dec 11, 2014 | 07:34 PM
Paul Vierra's Avatar
Question confusing fault code
I have a 2008 2500 with the 6.7 cummins. The check engine light came on so I checked it.Came back with a code of 2563.What the heck is this one? I can't find it anywhere.Any suggestions?
Old Dec 11, 2014 | 07:49 PM
BigIron70's Avatar
Cummins Guru
Most of the time that code means that your turbo is sooted up and needs to be cleaned, but then again the the tests could lead to turbo replacement. Read diagnostics and you will get a better idea of what tests need to be done to determine if turbo needs replacing.
File Type: pdf
PurNLoud
Jul 22, 2006 09:06 PM
Beavermike
Mar 1, 2006 09:05 PM
Lil Mule
Aug 7, 2004 01:17 PM
tippers
19
Jul 23, 2003 04:19 PM
