Check Engine light On
Old Jul 10, 2007 | 08:24 PM
megaturbo's Avatar
I was driving home this evening and my check engine light came on, I have read here on the forum that one may cycle the ignition 3x and on the fourth one that you can tell what the code is. Question, where does the code show up at? Any help would be appreciated. Thanks in advance.
Old Jul 10, 2007 | 10:15 PM
dodgezilla04's Avatar
megaturbo, welcome to DTR.
turn the key on and off 3 times then back to on. the odometer will display codes. it will start with a p and then 4 numbers, for example p0191
https://www.dieseltruckresource.com/...n&onlynewfaq=1
then click the link above and look up your code. post the code number on this thread, and we shall see what we can do to help.
Old Jul 10, 2007 | 10:51 PM
Dusty Ratcliff's Avatar
don't think this works on the 6.7L's??? at least that's what the dealer told me?? I tried it & got a bunch of weird letters & #'s, but none that made any sense????
Old Jul 10, 2007 | 11:14 PM
vzdude's Avatar
DTR's 'Go to Guy'
Post them, maybe I can make sense of them for ya!
Old Jul 11, 2007 | 04:17 PM
megaturbo's Avatar
Thanks for the info, but I got in my truck this morning and the overhead computer said that the catalyst was @ 100%. So I went to the dealer and the latest and greatest flash loaded. I am not holding my breath though that it is going to solve the problems.
Old Jul 12, 2007 | 08:07 PM
n0ne's Avatar
check your overhead display, it will tell you when your catalyst is getting full, all you have to do is go drive the truck at 60 MPH, 2000 RPM for 10-15 miles... the little Catalyst Stat bar graph will move down as it burns off the soot in the DPF, and the percentage will drop. When it drops to 70% or below it will say "System OK" instead of the Catalyst Stat & graph.
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
