4 wheel drive
Old Jun 7, 2009 | 01:03 PM
claydawgs85's Avatar
4 wheel drive
I put my truck in 4 wheel drive the other day and the indicator light telling you if in 4 high and 4 low was flashing. What does this mean. Should i be worried. I havent had a chance to put in back in 4 wheel since all the rain has stoped. If you all have any ideas let me know.
Old Jun 7, 2009 | 04:04 PM
DarkDesertCTD's Avatar
Usually if it's flashing it means that it's trying to go into 4WD but hasnt yet engaged.
Old Jun 7, 2009 | 04:14 PM
thanks for the info. ill see if it does agin next time im in 4 wheel.
Old Jun 7, 2009 | 06:57 PM
coolbreeze's Avatar
Explained in your owner's manual, along with a lot of other stuff. 4-hi is easy, 4-lo is different. Good luck.
Old Jul 8, 2013 | 12:33 PM
Dejay's Avatar
Angry My 4 wheel low dash light continues to blink
I can shift my truck into 4 wheel hi and note that the indicator flashes initially then when engaged stays lite as it is suppose too. However when I select 4 wheel low the light continues to blink and does not stop blinking indicating the low 4 wheel drive is not engaged? What should I be looking at to correct the 4 wheel low indication? Any help?
Old Jul 8, 2013 | 03:53 PM
RTillery's Avatar
You have to be completely stopped with clutch depressed or in neutral or park if automatic to go into low range. You can go to Hi 4wd or 2wd at any speed.
Old Jul 8, 2013 | 04:08 PM
Dejay's Avatar
Angry RTillery thanxs for the reply
I have a automatic tranny and I have tried what you have suggested many times and the indicator still blinks indicating that the Low will not engage?
Old Jul 8, 2013 | 07:48 PM
CALopez's Avatar
I know sometimes if you roll back gently in reverse on older vehicles the 4x4 will engage easier. Not sure about these trucks though.
Old Jul 8, 2013 | 08:49 PM
2006BLKMegacab's Avatar
if you can try it on a slight incline and let it try to engage 4 low while rolling backwards at a very slow speed in neutral, its been known to help from time to time
Old Jul 13, 2013 | 06:33 PM
Dejay's Avatar
Still have problem with 4 wheel low engagement
Tried to engage 4 wheel low while rolling slowly on a slight incline still no luck light continues to blink?
Old Jul 14, 2013 | 09:24 AM
at this time it seems like a trip to the shop is required, if it goes into 4 hi then it should in theory go into 4 low.
My Toyota tundra did something similar with just the light flashing and no 4 wheel drive at all and it was a burnt out actuator on the transfer case
Old Jul 14, 2013 | 03:51 PM
Reelay's Avatar
Is the truck engaging into 4 High or 4Low? If it is engaging then your indicator light switch is going out. Mine in my 2006 did that and I replaced the switch which is located on the transfer case.
L.J.B.
Jun 27, 2014 10:21 AM
roxxx
Apr 13, 2009 05:15 PM
04ctd
Dec 7, 2007 08:19 PM
gman2310
Sep 27, 2006 12:08 AM
Teddy
Nov 2, 2002 01:56 AM
