2007 PCM module
You haven't described your symptoms so it's pretty hard to help give advise on something without knowing your issues. If your at a Chrysler dealer they should be able to follow the standard troubleshooting protocals. If not I would be looking for a more competant dealer to work with.
Cummins Guru
Sounds like they are just throwing parts at it. What codes were setting? Dealership are required to give you print out when vehicle is written up in service drive of all codes stored and active. Did they give you a print out if not I would ask them for one. Then we can better help you. PCM and TIPM do fail but usually not at same time, ask them what DTC's were set in TIPM and PCM and what diagnostic tests were performed on your vehicle to confirm those modules needed to be replaced.
Zoochy
Apr 16, 2019 05:04 PM
