XRF Balljoints
Old Jan 22, 2010 | 10:03 AM
bumpytruck's Avatar
XRF Balljoints
Why does XRF not put grease fittings into the upper balljoints on our trucks?
Old Jan 22, 2010 | 01:01 PM
sallyman1's Avatar
i want to get these. where do u get them? u need a username and password on xrfchassis website. also are the upper or lower greaseable? how much are they for set of 4? are they the best right now for our trucks because i went through 2 sets of moog greaseable in the last 30,000 km... i need something beter or ill trade this piece of **** off on a ford or put ford suspension ,axles on my truck
Old Jan 22, 2010 | 03:36 PM
bumpytruck's Avatar
Try this item # on ebay 180450922878 They quoted me $56 each + shipping fron XRF.The lowers are greaseable tops are not and I posted here to find out why.The answer I got from XRF was not real good at all.I guess from my reading these are the way to go unless you wanna spend $600.I also read Moogs are not very good.The ebay price seems to be the best I can find right now.
Old Jan 22, 2010 | 06:00 PM
wiskeyVI's Avatar
I'm about with you sallyman....I test drove a 10 F$%D Lariat V10!!!
But from what I've seen on thier forums, their front ends aren't much better as far as bearings and such go.
Old Jan 22, 2010 | 06:30 PM
Sniper05's Avatar
XRF joints are the way to go unless you want to spend some coin on Carli or Dynatrac! They are priced good and last a while to, i have a set on order right now!
Old Jan 22, 2010 | 06:34 PM
Bluedeviltorque's Avatar
Bumpytruck,
What was the answer that you did get about the top joints not being greaseable. You say it wasn't good?
Mike
Old Jan 22, 2010 | 06:54 PM
snowball's Avatar
i've got 250000 km on the factory joints and they are still relatively tight. Gotta be how or where you drive. Do you do a lot of dry steering, are you out in the bush? Are they gone or did someone tell you they were gone. If so find a new mechanic.
Old Jan 22, 2010 | 09:31 PM
bumpytruck's Avatar
He never really gave me any kind of answer as to why there are no fittings on the tops.He said that they didnt need em but never said why not.I knew as much as i did before i asked.
Old Jan 22, 2010 | 10:00 PM
torquefan's Avatar
This is my experience too. Dodge allows quite a bit of play in these, and as long as they are within this spec there is no problem. Many people seem to be told that ANY play is bad, and it's simply not the case. Ball joints on many vehicles come from the factory with a certain amount of play engineered into them, and the suspension on those vehicles is designed to work with that. The alternative is aftermarket ball joints like Moog that are so tight the steering won't return to center by itself after you go around a corner.
Old Jan 23, 2010 | 04:41 PM
isb07's Avatar
id like to know too, i figured the lower wasn't greasable because of u-joint clearance. when i ordered mine through xrf they sad they were greasable.
i also got a set for my ford and there both greasable.
jhenson
51
Feb 1, 2019 09:57 AM
Hvytrkmech
Mar 27, 2012 05:04 PM
WHISTLINTURBO
Mar 13, 2011 10:47 PM
davehen
Oct 9, 2010 11:02 AM
