Won't start no codes
Old Sep 3, 2016 | 10:00 AM
bear58's Avatar
I have to use starter fluid to start then it runs just finest it's a pain to do ,what can i check?
Old Sep 3, 2016 | 02:59 PM
BigIron70's Avatar
Cummins Guru
Sounds like you have excessive return flow from injectors or the high pressure fuel tubes are leaking. Also make sure your batteries are fully charged and the starter motor is able to crank engine over to at lease 150 rpm. If you have a way to monitor rail pressure then I would start there. If not then I would tighten down all the injector connector tubes to 41 ft. lbs. If that works then you fixed your truck, if not then you need to cap injectors one by one until you find the one causing your no start. You will need a capping tool available online. 9864A Fuel Rail Block Off Cap 9864
Old Sep 4, 2016 | 09:43 AM
bear58's Avatar
Thanks for the info,that cap is for a6.7 mine is a 5.9 i don't know if that would work. All though i will tighten everything up and see what happens. Thanks again
Old Sep 4, 2016 | 10:48 AM
bullrambler's Avatar
If the batteries are a few years old - buy two new ones and install them. Sometimes one battery will get weak and the electrical system will draw off of the stronger battery. Eventually the better battery will fail.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
Machinos
Mar 16, 2008 01:34 AM
mbenedict
Jul 21, 2007 09:19 PM
