Whistle at 10psi
Old May 21, 2011 | 07:05 PM
workingdog's Avatar
Whistle at 10psi
My truck sat for a week, and when I got it back it had developed a loud whistle that comes on abruptly at about 9psi. Not a metal sound - definitely a whistle - much, much louder than the normal whistle of the turbo. If I keep my foot into it, I get's louder and then shifts pitch up. Acceleration seems fine. Stock engine except for a Smarty on a reasonable setting. Could there be a leak in the intake?
Peter
Old May 21, 2011 | 07:11 PM
C Schomer's Avatar
It could be a leak on the CAC connectors. The hot side loosen up often til you tighten them several times and then they will stay tight. Also a hole in a rubber connector. It doesn't take much of a hole to loose a bunch of boost and make noise. You have to check the connector very closely. I've had a hole on the bottom side that was hard to feel or see. Craig
Old May 22, 2011 | 08:41 AM
Nate-03 D's Avatar
A little off topic here, but do you have any pictures of the 68' w/ the Cummins in it? I'd really like to see that.
You didn't remove your silencer ring did you?
lgp9999
Feb 1, 2010 10:53 AM
natlchamp2k4
Mar 6, 2007 04:59 PM
Awall
Aug 1, 2006 07:54 PM
bgilbert
Oct 9, 2005 09:42 PM
