Where to buy driveline components?
I attempted to change my driver side u-joint today and ended up bending the yoke. I had to put it in a press to get the u-joint out and when I started putting it back together I noticed that the u-joint would not press in enough to get the snap ring on. The ear on the yoke is slightly bent in. It is stub shaft yoke, not the axle yoke. I assume there is no straightening it, so my question is where is the best place to get a stub shaft? Any help would be greatly appreciated.
I have had good luck with NAPA, O'rielly's and Advanced Auto Parts drive line parts. Just make sure they are made in China as the steel tends to be weaker. Saving the 30-50 buck cost your more in the long run.
cumminsho2500
19
Sep 12, 2003 10:56 AM
Hoss
Sep 3, 2003 02:50 PM
