When to change shocks???
Old Nov 12, 2008 | 02:03 PM
dale29's Avatar
Originally Posted by kertoncol
I have about 148,000 miles and notice a clanking noise after I go over small bumps. Could this be the shocks??? Thoughts???
Looking at replacing all 4 with Bilstein's from Geno's. Good or bad?
Sounds like the ol' sway bar end links need to be tightened or replaced, its the verticle black shiny bar with all the rubber around it, check the torque specs, I don't remember what they are.
Old Nov 12, 2008 | 02:19 PM
RDyson's Avatar
Originally Posted by D-Roc
Can Bilsteins be installed on a stock (ride height, and all stock suspension) truck? ANyone have part numbers for an 06?
The 5100's--silver with black boots will fit on a stock ride hight truck. That's what I have on mine. I got them from TopGunCustomz on ebay. I called them when I ordered to verify that they would work. Not sure on the #'s.
Randy
Old Nov 12, 2008 | 06:25 PM
johnh's Avatar
on mine the bushings went bad..... there's the noise
Old Nov 12, 2008 | 09:40 PM
ozpall's Avatar
ordered mines, bilsteins, should be here in a couple of days.
Old Nov 13, 2008 | 08:37 AM
Sam Turner2's Avatar
How much better are the bilsteins than Rancho, I changed my stock shocks for Rancho's at 100K and notice little improvement.... not $200 worth... My truck is very heavy if I'm full of diesel I wiegh in the mid 8,000lb range, Is there any way I can put a second shock on the back?
Old Nov 24, 2008 | 07:14 PM
reaves11's Avatar
The knocks over small bumps that you hear are the sway bar bushings and links. They come in 3 sizes, 34mm,33mm and I think 30mm. It a wonder just how much noise comes out of those bushing and are easy to change.
Old Nov 24, 2008 | 08:55 PM
kertoncol's Avatar
Thanks. I did change all 4 shocks and the ride seems a little bit better but the sounds are still there. Where is a good place to buy these bushings and how do I know what size I need (or are you saying I need all three sizes)?
Old Nov 24, 2008 | 10:50 PM
n2moto's Avatar
Change them when you drive it off the lot.
Old Nov 25, 2008 | 05:09 PM
mini14's Avatar
check to c how loose your control arm bushings are.thats what u could be hearing
Old Nov 29, 2008 | 03:53 AM
04ctd's Avatar
what brand of shock does NAPA have?
my buddy is a manager, gives me a good price, and just brings me a trunk load of parts to church.
saves me a lot of time
Old Nov 30, 2008 | 10:56 PM
harwill's Avatar
Common source of clanking - the receiver hitch. Assuming the insert is installed.
Old Dec 29, 2008 | 03:51 PM
thatguy's Avatar
Can the average joe change out the shocks or are there any special tools needed?
(for the record I know Im in the wrong forum, I have a 2002 but found this while searching about replacing shocks)
Brian
Old Dec 29, 2008 | 05:14 PM
mikelr's Avatar
Originally Posted by D45
The stock shocks typically last 35,000 miles.....
I thought it was 35,999 miles
Old Dec 29, 2008 | 06:57 PM
ozpall's Avatar
Brian
Brian, its pretty simple, regular sockets and wrenches, on 3rd gens we have to remove 1 battery out of the way but that's about it. it should take about 1 hour depending on how rusty your bolts and nuts are.
Old Dec 29, 2008 | 09:41 PM
w.tx iceman's Avatar
Lightly press on brake and see if noise goes away, pads can rattle pretty bad.
