wheels
Old Jan 22, 2007 | 06:04 AM
genros's Avatar
wheels
Will these rims fit on my 05 ram 2500
here is the spec
0 TO 15MM AND THE LUG IS 8 14 X 1.5 AND THE DIAMETER OF THE CENTER HOLE IS 125MM
Old Jan 22, 2007 | 10:37 AM
genros's Avatar
ok any insight as to who to call to find out?
they are rims i can get for a deal off a hummer. Im good with the center (I can machine it if needed) but the backset i dont know
Old Jan 22, 2007 | 10:54 AM
morkable's Avatar
If they are off of a hummer they should fit other than the center, if you do a search on here regarding h2 rims or hummer rims you will find days worth of reading
Kevin
Old Jan 22, 2007 | 11:51 AM
nitis's Avatar
if they are 17 inch H2 wheels I have them and they look good imo will stick out more than stock but just enough to look good and not stick out obnoxiously
Old Jan 22, 2007 | 11:56 AM
ptgarcia's Avatar
What is that 0 to 15mm measurement? The offset? If so, which is it, 0 or 15mm? And what size wheel? Most important is the width.
Old Jan 22, 2007 | 12:52 PM
genros's Avatar
they are ten inches wide, im assuming the 15 is the setback
Old Jan 22, 2007 | 03:06 PM
ptgarcia's Avatar
The wheel will fit, but because they are 10" wide they are going to 1) stick out about 2" farther than stock and 2) will cause rubbing with anything larger than 33" tire unless you bolt up about 4.5" of lift. I strongly suggest sticking to a 9" maximum width wheel.
bucknasty
Jan 10, 2008 06:52 PM
tontof18
Sep 28, 2006 07:59 PM
Dave88LX
Jul 13, 2005 08:34 AM
Gary C
27
Mar 11, 2004 07:42 PM
