What miles did you change Dino to synthetic oil and did your engine start leaking?
I am using ESSO 0w40 synthetic oil. The number 40 is the one which is important at high operating temperatures. I think you should be more concerned if you have a second number lower than 40. The first number has to do with how well the oil flows when cold- it has nothing to do with the oil being "thinner" when the engine is at high temperature. In fact, with a good quality synthetic oil, it should be useful to have a lower first number, because when you start your truck cold, the oil pressures up faster. The "lighter" oils at high operating temperatures are the 30 weight oils- eg. 0w30, 5w30, 10w30, or 15w30. 40 weight oils are recommended for the Cummins.
edit- I should have said that when warm the viscosity acts as a higher number-IE 40 weight at operating temp. It will always be more viscous when cold.
Cummins Corporate website says it's OK to switch to full synthetic in these motors after break in period which depends on how you use your truck the first 10-20k miles. I switched at 15k to Amsoil. No problems.
From the Cummins website
Is it OK to use synthetic oil with my Cummins engine?
Cummins recommends that you not use synthetic motor oil during the break-in period. The Owner's Manual contains information on the type of oil that is recommended throughout the life cycle of your engine.
In general, the engine requires 5000 miles for break-in. This depends on the type of driving the truck is subject to; hauling or towing a load will shorten the break-in period. Light duty hauling or "babying" the engine can delay full engine break-in for up-to 20,000 miles. It is best to avoid high engine rpm's during the break-in period.
Been in it sents new.
