What fluid for trans case & 6 SPD?
I just purchased an 04 with 150k miles. I changed the oil and am going to to do the diffs. I want to change the oil in the transfer case and transmission as well but am unsure which fluid to use,
Transfer case is ATF4. For the transmission you can use the expensive special Dodge 6 speed oil or the Penzoil Synchromesh Manual Transmission fluid. There are other suppliers as well. DO NOT use ATF 4 in the tranni as some recommend.
zx14on2
21
Oct 28, 2009 11:10 PM
Mark Hodowanec
Jul 28, 2005 07:22 PM
