what do these codes mean????
Old Nov 11, 2007 | 09:17 AM
ChrisM55's Avatar
My Moms new 07 5.9 w/ 6K miles on it is throwing these 2 codes and sometimes will not start. First is a P2509, and the other is a P0513
The 2509 is some kind of a data loss error but I can't find the other. I know it needs to go in to the shop, but I still like to know what the heck is going on
Chris
Old Nov 11, 2007 | 09:28 AM
ronc's Avatar
P2509=ECM/PCM Power Input Signal Intermittent. Cannot find P0513.
Old Nov 11, 2007 | 09:32 AM
t-boe's Avatar
P0513 has something to do with the Sentry key system, I think.
doug duncan's Avatar
here is a link for all of them
http://www.dodgeforum.com/m_691136/tm.htm
Old Nov 11, 2007 | 09:33 AM
ronc's Avatar
P0513=Incorrect Immobilizer Key. New key cut lately or alarm system installed? Hope this helps a little.
Old Nov 11, 2007 | 09:36 AM
donnee's Avatar
From what Iv found, the 0513 code has to do with the vehicle speed and idle control.
Old Nov 11, 2007 | 09:45 AM
DaveB.inVa's Avatar
0513 can be caused just from a simple miscommunication between the key and truck. I believe I caused my truck to throw this code on purpose. I'm a code checking nut and check regularly. I checked once after shutdown and no codes. Fired it up for a short trip and tried to check after the very next shutdown. Only this time I had the door open and I'm pretty sure I cycled the key too fast. After realizing you cant check codes with the door open, I closed the door, checked and up came 0513!
Its supposed to clear itself after a few starts. Last time I checked it was still there. I've got the Smarty and can clear it but I'm going to see if it'll clear on its own. I'm laid up right now with a broken femur so I've not drove the truck in a little while or I'd go out right now and see if its still there.
Old Nov 11, 2007 | 10:23 PM
ChrisM55's Avatar
so it looks like thje 2509 is the issue?? Is this going to be one of those awful ground issues????
Chris
Old Nov 13, 2007 | 03:43 PM
DieselBoy20's Avatar
I got that 2509 code recently and it came up only because I was unhooking my batteries, its a data loss error code, i don't think it has anything to do with your problem. Your problem is miscommunication between the sentry system and the keys....
powerstrokin03
Dec 6, 2005 08:11 AM
benny
Oct 16, 2005 01:39 PM
boughtadodge
Jul 7, 2005 11:34 PM
cumminsman02
Apr 29, 2005 09:02 PM
Farmall
Feb 3, 2003 09:07 AM
