What caused engine light to come on?
Old Oct 6, 2003 | 12:09 PM
Sittenbull2's Avatar
Changed engine oil and filter cranked it up ran rough than smooth out then engine light came on any hints to what might be the problem? Also noticed for about 2 weeks or so in the morning when first cranked and running it kinda surges till warmed up oh say 20 to 30 rpm difference. Any help with this diagnostic did the code check and no codes.
Old Oct 6, 2003 | 05:09 PM
mymaur's Avatar
Re: What caused engine light to come on?
I have had my eng light blink on a couple of times. But just for a second and it goes out. I have read on this site of others having a similar occurence.
As long as it goes out and gauges are normal I ignore it.
Old Oct 6, 2003 | 05:21 PM
spots's Avatar
Old Oct 6, 2003 | 05:22 PM
spots's Avatar
Did you bump any connectors or check the air filter? There is a connector on the air filter housing.
If your grid heaters are cycling your rpm may fluctuate.
Old Oct 6, 2003 | 05:54 PM
Rolngthun's Avatar
[quote author=Sittenbull2 link=board=20;threadid=20612;start=0#msg193462 date=1065460149]
[/quote]
Did you prefill the filter? If it took a while to get oil pressure it may have set a code for low oil pressure. Normally it should become an inactive code once it see pressure and turn the lamp off though.
Only way to know for sure is to get a scanner on it and retrieve the code.
Old Oct 7, 2003 | 07:13 AM
RamDan03's Avatar
[quote author=Rolngthun link=board=20;threadid=20612;start=0#msg193643 date=1065480883]
[/quote]
That's what I was thinking too. Since the filter holds an entire quart of oil, it may take a while for the pressure to come up if it wasn't pre-filled.
Also, if you live near an AutoZone, they can retrieve the code for free with their OBD-II reader.
Old Oct 7, 2003 | 07:54 AM
Thanks yallfor your help.Spots I could have bump the connector, RolngThun, Yes sir filled the filterfull it might have settle though alittle,and last but not least RamDan03,Thanks I will get them to check it for me. Good news it still runs like a Cummins should purrs like a Beast. ;D
Old Oct 7, 2003 | 05:07 PM
spots's Avatar
I would highly doubt that an oil pressure issue would put on the amber check engine lite. Usually engine issues are red (stop now) and emission issues are amber. (drive it but get it looked at)
Old Oct 9, 2003 | 11:57 AM
kingofdodge7131's Avatar
Do the third gen trucks have the same key combo like the 2nd gens did to show ya the code?
Old Oct 13, 2003 | 12:49 PM
ttreibel's Avatar
Turn on the key holding down the trip ODO reset and after the self test should display any codes if present in the system.
Old Oct 14, 2003 | 06:38 AM
turbov6joe's Avatar
Is that the trip reset by the speedo or the overhead?
Old Oct 14, 2003 | 09:17 AM
Jonesey's Avatar
[quote author=turbov6joe link=board=20;threadid=20612;start=0#msg196585 date=1066131519]
[/quote]
Speedo.
Old Oct 15, 2003 | 07:05 AM
turbov6joe's Avatar
I did just that and all it did was reset my trip odometer??? Is the reset button sopposed to held down while turning the key on?
Old Oct 15, 2003 | 09:07 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
I believe you hold the button and cycle the key three times or something like that.
Old Oct 15, 2003 | 10:03 AM
cby52's Avatar
Hold down the trip button and turn on the key, don't start. The self-test will run and after it's complete you see the e-code in the odometer display. I kept doing the self-test when I was trying to get the engine hours to display.
