Weird volt reading on startup
Old Dec 13, 2007 | 06:46 PM
CoolumConst's Avatar
Today whenever I started my truck I noticed that the volts would not come up for atleast a minute. It did not matter what the rpms were. The volts would be about 12volts and after a minute the volts would get up to about 15-16. Anybody have this problem.
Old Dec 13, 2007 | 06:52 PM
gunny's Avatar
Grid heater was on, it will draw more amps than what the alternator can supply so the batteries make up the difference.
Old Dec 13, 2007 | 06:56 PM
That is what I thought but it was not cycling the voltage and the engine was at operating temp.
Old Dec 13, 2007 | 08:02 PM
05 CTD2500's Avatar
There was another thread stating that the volt meter is actually only simulating what the computer thinks it should be while the grid heaters are cycling, hence why it doesn't go up and down as you hear the relay clicking. Supposedly even if you remove the grid heaters the guage will still drop on a cold start. Mine cycles the grid heaters when started even if already at NOT too usually, not real sure why this happens.
Old Dec 13, 2007 | 08:17 PM
Raspy's Avatar
It's not the grid heater because that cycles on and off with no change in the reading. It's more about when the computer turns on the alternator and when the gauge shows the reading. No worries, they all do it.
John
Festus
Mar 2, 2011 01:00 AM
chuckybones
Jul 22, 2008 05:55 PM
12valve@heart
Mar 7, 2005 12:19 AM
Dieseldude4x4
Jan 4, 2003 03:07 PM
