Weird new noise
Old Aug 5, 2009 | 12:10 PM
Devinraptor's Avatar
Weird new noise
I have a weird noise that I have never heard on this truck before. I bought gas the other day and by the time I got home I had this ticking/knocking sound coming from my engine. I'm not sure what the cause is other than maybe some bad diesel. What can I do to fix it? Or is there something else going wrong. It sounds like a valve tap or exhaust leak. I hear it slightly at idle and then I can hear it all the way up to about 40 MPH after that it gets to noisy. Its not very loud, in fact I have to have the windows up and the radio on low to hear it. I just don't like it not being normal. Thanks for any help.
Old Aug 5, 2009 | 04:38 PM
I tried adding a fuel additive and I even filled up the truck again from a different station and it still doing it any ideas?
Old Aug 5, 2009 | 08:42 PM
.boB's Avatar
A ticking/knocking sound could be anything from a bad valve to a loose exhaust manifold. You'll have to dig around and locate the sound a little better.
A good trick is to get some rubber vacuum hose. Put one end into your ear, and move the other end around until you hear the sound better, Kind of like a stethescope. For deeper engine sounds, use a long screwdriver with a plastic handle. Press the plastic handle against your ear, and lightly touch the block and heads with the other end. Use the longest thinniest one you have.
Old Aug 5, 2009 | 09:24 PM
I have narrowed it down a little. It is coming from the right side of the motor (facing truck) It sounds to be somewhere from the fuel filter up to about the just before the fan. Thats about all I can diagnose tonight. If anyone can give me anymore pointers I'd appreciate it. I'll keep posting whatever else I can find.
slorocco
Apr 13, 2009 06:15 PM
Common
Apr 9, 2008 10:25 PM
DanHfmn
Jan 18, 2006 09:37 AM
Hummin Cummins
May 1, 2005 06:25 AM
Hired Gun
Jan 29, 2003 06:43 PM
