View Poll Results: Have you had to have your truck worked on under warranty
No - Never
26
27.08%
Yes - In the first 6 months
51
53.13%
Yes - In the first year
16
16.67%
Yes - In the 2nd year
2.08%
Yes - 3rd year to end of warranty
1.04%
Voters: 96. You may not vote on this poll
Warranty Work
Old Jun 17, 2004 | 01:52 PM
TexasTodd's Avatar
Warranty Work
Just curious as to how many of you have had your trucks back to the dealer for warranty work.
Old Jun 18, 2004 | 06:07 PM
DFD536's Avatar
Not yet, but it is only 4 days old, so I have plenty of time
Dennis
Old Jun 18, 2004 | 07:40 PM
ZS's Avatar
ZS
Are you counting recalls?
Old Jun 18, 2004 | 10:10 PM
AaronT's Avatar
I think another good poll would be "Have you had your truck in to have a problem corrected and did they fix it"?
Had truck in but was told this is normal, nothing wrong!!
I am 0 for 5.
Old Jun 19, 2004 | 10:00 AM
nirion's Avatar
Had mine in during the first 6 months to fix the A/C, which never worked. There was a leak and after recharging it and adding dye, they replaced the condenser. But the problem appears to be solved.
Nick
Old Jun 19, 2004 | 11:26 AM
Miles PH's Avatar
Had mine in 4 times So far 1ST clearance lites leaking 2CD drivers seat you can feel the metal bracket threw the foam padding 3RD lights again factory overtightened 4Th recall on transmission line. And very happy with service so far. But NO loner trucks provided not very happy with that policy.
Old Jun 23, 2004 | 11:06 PM
dodgezilla04's Avatar
Thumbs down
Yes, once on the 3rd week of ownership, and once on the 4th week. both for code 0191, low fuel pressure. The dealer had to contact STAR to get permission to order the pressure sender. 3-5 days shipping. However, the truck runs just great and the mileage is the same.
Old Jun 24, 2004 | 08:40 PM
jwtuc's Avatar
YES , 5 times for engine miss ( finally, 6 new injectors!) , reflash for a/c . Will be going again for mileage reflash when it comes out .
Old Jun 25, 2004 | 06:31 AM
butchera's Avatar
Had the tranny recalls done and the alt bracket TSB done. Took them three day to do that. Not real happy with that dealer.
Used my Dad's dealer to have the tranny serviced. From drive in to drive out took 2 hours and very happy with that dealer. Unfortunatly that dealer is 400 miles away.
Old Jun 25, 2004 | 12:46 PM
el jefe's Avatar
Took mine in Feb. 03 for the clutch rattle at about 4500 miles and they told me it was normal. Then took it back in late April or early May of this year at 24000 miles and since the dealer had documented it the first time under 12000 miles they performed the TSB under warranty, otherwise they wouldn't have. They also didn't say anything about my gauges or exhaust and I took my EZ off a week and a half before my appointment so they wouldn't deny the repair under warranty. Funny thing was, they had a book of all Dodge products dyno charts and on the back of the cummins dyno was a cummins+EZ dyno!
Old Jun 25, 2004 | 04:46 PM
Scrappy's Avatar
warranty work
mine has only been back to the dealer one time for an oil change and speedo recal since it was born. I posted in the wrong spot in the poll.
Old Jun 25, 2004 | 07:51 PM
Sorehead's Avatar
Had mine in for leak at rear of Trannie. They replaced seal, yoke, and U-joint. They don't carry any parts in stock. So it becomes a time thing. My work truck, so I need it.
Old Jun 28, 2004 | 07:35 PM
SageBrush 1's Avatar
03 3500 dually 4x4 QC Laramie. 12K miles.
6 visits for the A/C over a year, I think its fixed now... new compressor, sensors, coil, blower housing.... 2 visits for the clearance light leaks. 2 for the power windows binding up. Plus the recalls and TSB's which took two visits. Had the power steering hose TSB done, vibration remains from 65 to 70 mph. The dealer fixed some dash noises. The A/C was a real pain, the dealer had a very hard time finding the real problem. They just threw parts at it.
Truck runs good now, except for some droan which I can live with. My 98 had zero problems, I guess this truck makes up for the trouble free truck.
The dealer did provide a free loaner/rental truck three times. About two weeks worth. Three Ford SuperCrews
Kinda stinks when you need to pull something, those things are more like cars than trucks. Better than nothing though. At least we got a loaner.
Old Jun 29, 2004 | 01:48 PM
schorb's Avatar
Wow! This is starting to look like if you can make it through the 1st year, you've got it made!
Old Jun 29, 2004 | 09:15 PM
Journier's Avatar
ive had mine in 2 times now.
first time, Vibration
2nd time mirror was smashed sorta by dealership
3rd time, dealer ship got scratch/dent in the door....
4th time.... probably soon i dont know but these trucks seem to have many troubles... i just hope the god **** engine holds up for 150000 miles.
LFD2037
Jun 8, 2008 01:36 PM
gandalf1g
Nov 26, 2007 02:31 PM
trik396
May 30, 2007 04:42 PM
DarrellB
Dec 26, 2002 10:50 PM
