Walbro ?
Old Sep 13, 2008 | 07:33 AM
doug60's Avatar
Walbro ?
The CP3 seems to be able to pull fuel through the walbro .
My circut breaker is acting up. Pump is cool to the touch though.So I dont think is drawing to much current.
When the pump stops the engine does'nt.
Is it the design of the pump?
When my fuel pump failed (not a walbro). The engine stalled.
After a quick call to Floor it. I bypassed the pump & drove home.
Im not saying I would'nt bypass it if it failed but it is a good feature for safety.
Old Sep 13, 2008 | 09:42 AM
JWH_03_Dodge's Avatar
I'm pretty sure my GDP walbro came with a fuse, not a breaker. What is the rating on the breaker? I guess it would depend on the style of the pump on whether it can pull it though it or not.
Did the truck act any different when the pump cuts out?
Old Sep 13, 2008 | 09:59 AM
spooled05's Avatar
When my walbro went out the cp3's still pulled fuel,i tapped on mine w/a screwdriver and it would start working again.Got me by until i got new l/p
Old Sep 13, 2008 | 01:32 PM
doug60's Avatar
No it does not act any different at idle or light acceleration.
I got the relay with a painless wireing kit, Im not sure how many amps it is.
I just got finished removeing the breaker & installed a mini fuse holder.
How many amp fuse does the walbro kit come with?
thanks,doug
Old Sep 13, 2008 | 02:20 PM
doug60's Avatar
Amp Draw
I found a chart , at 20 LBS it draws 6 amps.
I put in a 10 amp and it seems to be holding.
With the help of a fuse buddy , that would be a good way to check the condition of your filters.
If you see it drawing more amps , time to change the filters.
Old Sep 13, 2008 | 06:28 PM
mine has a 15A mini... normally fuses are sized at 1.5 times full load amps, can you send me a link to the walbro chart?
The 10A you have should work, if it pops, upgrade to the 15A and keep us posted.
rich2500
Feb 1, 2006 08:03 PM
Superduty
Jan 25, 2006 08:02 PM
Superduty
Jan 25, 2006 12:24 AM
Superduty
Jan 11, 2006 01:25 PM
roadranger
Jan 6, 2006 03:07 PM
