vibration seat and steering wheel
Old Oct 5, 2006 | 08:19 PM
HawaiiCTD's Avatar
Does anyone have a vibration at idle that you can feel in the steering wheel and the seats?
I have noticed this within the last few days, nothing major just a slight buzz that was not there before.
the truck just hit 33,500 miles.
Old Oct 5, 2006 | 08:38 PM
iweb's Avatar
Mine started this at 10,000 miles, I now have 14.500 and its still there, mostly at stop to 45 mph.
Old Oct 5, 2006 | 08:40 PM
Smokeman's Avatar
I think their might be a TSB for that. they tie a big weight on one of the power steering lines.
Old Oct 5, 2006 | 09:22 PM
HawaiiCTD's Avatar
anyone hear of a fix?
Old Oct 5, 2006 | 09:52 PM
stock03's Avatar
Mine does that at about 2000RPM...At about 2500 it's as smooth as a gas motor. At idle it doesn't seem too bad. But I might be used to it. 56,000 miles.
Old Oct 6, 2006 | 04:24 PM
bighornram's Avatar
Mine does the same thing once in a while. Try running some fuel additive in your next tank, preferably one that disperses water. Seems to clear it up for me for a while.
Old Oct 6, 2006 | 07:46 PM
Jeff in TD's Avatar
My 03 had a Kazoo like buzz in the dash, right at 2,000 RPM. After a couple of trys, I suggested this steering hose TSB, which solved the problem.
The updated hose is supposed to cure vibration in the steering wheel and/or pedals, which in some trucks only happens around 2,000 RPM...
I think some of the 04's might have also gotten the old style hose.
The hose in question is the pressure supply line between the power steering pump and the hydrobooster. The old style is just a straight piece of line, and the new one has a big metal weight, and a metal crimp joint mid span, about adjacent to the battery.
http://dodgeram.info/tsb/2003/19-008-03.htm
Old Oct 6, 2006 | 08:22 PM
HawaiiCTD's Avatar
My vibration is at idle and is not only in the steering wheel, but can also be felt thru the seats.
This only started happening about a week ago.
I run a mix of silver ps and mmo mix in every tank.
Old Oct 11, 2006 | 12:44 AM
stock03's Avatar
Jeff in TD, thanks for that info. I'm going to get mine fixed ASAP. Is that a recall and covered under warranty? Or will I have to pay for it? I'll buy the parts and do it myself if I have to pay for labor.
Old Oct 11, 2006 | 03:19 AM
BigDave12768's Avatar
No need to worry about this. The 3rd gens came with the massaging seat option. You must have turned it on by accident. The button is on the door by the window switches. It's a nice option to have after a hard day of work
Old Oct 11, 2006 | 07:38 AM
Jeff in TD's Avatar
Stock03, it's not a recall, just a technical service bullitin- basically a notice to technicians about a known problem, and what the solution is.
If your truck is still under full warranty, it should be covered. If not, the link to the TSB lists the part number of the required hose...
bcool
Feb 11, 2008 06:04 PM
yaitsfast
Feb 5, 2007 04:52 AM
TEXWS6
Dec 19, 2005 07:37 AM
Drafter
Dec 11, 2005 04:08 PM
MikeyB
Dec 11, 2003 08:55 AM
