vibration in injector line
Old Dec 9, 2010 | 03:28 PM
loya 3500's Avatar
Question vibration in injector line
My truck has been doing it for about a month and have not really worried about it to much. beacuse it has not efected the running of the truck.
there is a vibration and a ticking noise. in the first injector line on the front driver side of the engine.. you can not feel the vibration unless you touch it. but you can hear the ticking all the time..
what could the be the cause of this? bad injector? they are stock with 171k on them
Old Dec 9, 2010 | 06:05 PM
JJPage's Avatar
The vibration is normal, check the tightness of the clamp(blue plastic) securing that line, and the other lines as well. If the clamp is loose, it will tick and eventually break the line.
Old Dec 9, 2010 | 06:24 PM
homewrecker's Avatar
The first line, injector #1 does not not have a clamp. The vibration/pulsing is normal. But JJ is right about making sure the line clamps on the others are tight. #4 is notorious for coming loose and cracking the line.
Old Dec 9, 2010 | 07:55 PM
loya 3500's Avatar
thanks guys.. i was just about to add that it is more of a pulsing/vibration and there is no clamp on #1..
but I will look at the other lines to see if maybe thats where the ticking is coming from
Old Dec 10, 2010 | 07:26 PM
JJPage's Avatar
You are correct, there is no clamp on 1 or 6. 1 does come very close to the grid heater ground and wire harness, as much as 1 vibrates I would try and clear everything out around it.
Did you find the source of the ticking?
Old Dec 13, 2010 | 02:19 PM
loya 3500's Avatar
no still have not found the ticking. but it i think its is coming from the #1 injector.
loya 3500
Dec 9, 2010 10:48 PM
dodgedsl03
Jan 18, 2007 10:08 PM
00 5.9 ctd
Jan 17, 2006 10:08 AM
Dieseldude4x4
Apr 16, 2004 09:05 PM
DF5152
Apr 17, 2003 07:42 PM
