Vibration at idle
Old Oct 13, 2008 | 07:50 PM
bubba40's Avatar
Unhappy Vibration at idle
Hi all,
First post so please bear with me.
Just today I experienced a noise I could hear only at idle.
It sounded similar to a cell phone on vibrate.
It would occur at about 30-40 second intervals and last for about 2 seconds. This went on for as long as I cared to run the engine at idle and listen (about 5 minutes).
Truck is very lightly modded. I have 132k on the clock so far.
Heard this one before?
Thanks.
Old Oct 13, 2008 | 07:59 PM
P.J's Avatar
P.J
You uh, do have the Cummins diesel option, right? My truck is fairly loud at idle with the dual disk, I wouldn't notice a cell phone vibrating.
Just kidding. Auto or stick?
When you tap the go pedal, it goes away?
You positive it's not a standard interior BSR? (buzz, squeak, rattle)
Old Oct 13, 2008 | 08:44 PM
Power Ram 4X4's Avatar
If it is an automatic truck i have had the electric vacuum pump make that noise usually caused by the vacuum line getting a hole in it.
Old Oct 14, 2008 | 10:43 AM
Spitse's Avatar
That electric pump is on the passenger side behind the battery and the coolent fill container. Are you having trouble with the Cruse Control?
I had a small nick in the line off that pump, a small black line that T's off in the middle of the firewall. The pump would cycle quite often till I totally lost Cruse because the pump burnt out (Dodge thought it was for the Break system, but I never lost the breaks even after the pump died).
Old Oct 15, 2008 | 10:37 PM
bubba40's Avatar
Yes it's an auto trans.
I am positive its not a BSR.
If it is the electric vacuum pump would I notice any problem with the cruise?
This noise does seems to be very consistent.
Engine performance seems completely normal....
Old Apr 10, 2010 | 07:51 AM
johnshole's Avatar
Do you still have this vibration? I have developed it with no idea what it is.
Old Apr 10, 2010 | 06:53 PM
rich's Avatar
check your injector line holders mite be loose
dodgedsl03
Jan 18, 2007 10:08 PM
89dieselkong
Nov 23, 2005 04:01 AM
Jdub
14
Sep 25, 2003 04:44 PM
deje
Aug 29, 2003 05:50 PM
Evildiesel
Aug 1, 2003 11:28 PM
