Vibration at 70 MPH - Help
Old Apr 18, 2015 | 07:52 PM
eastmentCTD600's Avatar
Exclamation Vibration at 70 MPH - Help
I have a vibration at 70 MPH which blurs the traffic I see in the rear-view mirror. Under 70 MPH seems to be fine, but not perfect.
  • When I remove the front driveshaft the vibration goes away completely up to 104MPH - smooth as silk.
  • I had the front driveshaft rebuilt; when I re-installed it the vibration came back.
  • I've had the front shaft balanced a total of 4 times: 3 times by the shaft rebuilder, then I got frustrated and had it balanced again by another major and reputable shop. Vibration persists.
I also have some minor radial slop in the front output of the T-case. I don't know if this is the cause of the problem or if the slop exacerbates a marginally balanced shaft.
Therefore I need to look at another truck to determine if the slop in the T-case front output is normal or excessive.
Could someone in Colorado in the Denver/Golden/Lakewood area with a 2003-2005 Ram 2500 4x4, QC, LB please contact me (PM or post) so I can look at your truck. All I need to do is grab the front T-case output and check radial play; additionally I would need to know if the truck has any vibrations at speed.
Can someone please help?
Thanks in advance,
Eric
Pinkston
Oct 25, 2011 08:27 PM
nitrous
13
Jun 5, 2010 12:46 PM
treemonkey
Jun 17, 2009 02:06 AM
Mark Hodowanec
Nov 13, 2004 11:02 PM
Mark Hodowanec
Nov 10, 2004 06:41 PM
