VGT turbo on 2005?
So the rumor is floating around that a VGT turbo will be on the 2005's. Anyone have any further data to back that up?
Two thoughts.
1 - The only changes my dealer noted were color and a factory sunroof. 2 - They just revised the engine for 04.5, I doubt they would put two big changes so close together. |
Originally posted by stevenknapp 2 - They just revised the engine for 04.5, I doubt they would put two big changes so close together. |
VGT
VGT,...stands for what or who.
Variable Geometry Turbo. ( thanks Rusty for the correction :) )
Its not a bad thing as long as its done right and parts from a Kia aren't used on it! Jason:) |
With all respect, VGT = variable geometry turbocharger.
Rusty |
VGT
Originally posted by RustyJC With all respect, VGT = variable geometry turbocharger. Rusty |
A variable geometry turbocharger has moveable guide vanes for the turbine (hot) section. These vanes are controlled by the engine control system. At light loads or low RPM, the vanes are in their minimum area position - this makes the turbo behave like a "small" turbo for quick spooling and minimal smoke. At heavy loads or higher RPM, the vanes open to increase the nozzle area to reduce exhaust backpressure and pre-turbo EGT as well as to prevent turbocharger overspeeding - effectively making the turbo behave like a "large" turbocharger.
Rusty |
Re: VGT
Originally posted by OT-OF-Here Sorry, just not tuned in on this VGT stuff. An example of a VGT Turbo would be? and who is making them? Benefits? |
Also, the 6.0 PowerJokes use them, as if that is a good thing.
That is why they sound so wicked straitpiped leaving a stoplight. Sounds like a 747 taking off. Chris |
Rumor I heard is they are switching to the VGT right away (sometime this month)
VGT turbo on 2005?
The June 2004 issue of Motor Trend's Truck Trend, which has a very nice write-up on the 600, says in part " ... a larger compressor within the same HX35 housing, an electronically controlled wastegate (to get the benefits of variable geomerty without complexity), and a controller with about 50-percent more code in it. An EGR system isn't necessary, which saved roughly 50 part numbers and a lot of plumbing..." Hope this helps. cheers f http://www.trucktrend.com/features/t...ram/index.html |
Dont believe rumors.........
The VGT is also water cooled , and from the factory rep said , it could also act as a exh brake.... it would be a good rumor but I doubt that DC will reprogram the ecm for them along with added sensors required for it to work .
vgt questiono
Originally posted by FrankB VGT turbo on 2005? The June 2004 issue of Motor Trend's Truck Trend, which has a very nice write-up on the 600, says in part " ... a larger compressor within the same HX35 housing, an electronically controlled wastegate (to get the benefits of variable geomerty without complexity), and a controller with about 50-percent more code in it. An EGR system isn't necessary, which saved roughly 50 part numbers and a lot of plumbing..." Hope this helps. cheers f http://www.trucktrend.com/features/t...ram/index.html |
