Valve lash question
i dont believe the 150k miles before valve lash. I did my first one at 40K and my second one at 65k (the second one was because i put my F1 valve spring in and let them seat for 2k miles) but still, both times reduced the rocker noise down considerably. I am at 80K now and will probably do another before this summer.
Setting the exh. valve tighter (say .016" but no more) this will increase duration and lift slightly which does provide a noticable, however slight, faster spool. A side effect to this is decreasing the incylinder EGR which will show up on your pyro as increased EGT even though actual in cylinder EGT remains unchanged.
Administrator/Jarhead
I don't go with the cummins spec either on when you should do it.
I adjusted mine the first time when the head studs went in, and every time I've had the valve cover off... Most times they are all in spec...
Is the gasket with the injector connections reusable?
VaultRam
Nov 18, 2013 08:11 AM
RyeThomas
Jul 18, 2011 03:38 AM
REDNECK-WELDING
Apr 4, 2008 06:06 PM
