V-Band Clamp for Turbo
Old May 19, 2007 | 09:14 PM
nineback's Avatar
Is it possible to replace the V-band clamp that clamps the cast iron elbow to the turbo without having to remove the turbo? The bolt that tightens the clamp broke I and can not tell if the clamp actually comes all the way part to allow it to go around the turbo without having to slip it over one end.
How critical is this clamp? The turbo and cast iron elbow sure seem tight. I need to use the tuck until I can get a new clamp.
Follow up- Dealer is having a hard time finding the clamp. It is different from the one on the exhaust elbow.
Thanks,
Tom
Last edited by nineback; May 21, 2007 at 04:42 PM. Reason: Added Follow up information
Old May 19, 2007 | 09:24 PM
irocin350's Avatar
on my 03 when i did a turbo back system it came w/ new clamps looking at the old one if you brook the bolt you would need a new one cuz its kind of like a "t"but if you brook the nut then just change the nut.id like to help ya but your prob 600 miles away
Old May 19, 2007 | 09:54 PM
irocin350's Avatar
yes it can but it will be fun
Old May 20, 2007 | 05:01 AM
Dodgezilla's Avatar
And you will get an exhaust leak if you drive it without the clamp. My dealer wanted $50.00 for one of those clamps!!!!!!
Old May 20, 2007 | 06:14 AM
nineback's Avatar
OOPS. I just checked again. It is not the clamp that attaches to the cast elbow. It is the one right behind the turbo and right behind what I am guessing is the oil supply line (chrome).
Is this also a V-Band clamp? It looks a little different.
I am assuming that the only effect of this clamp will be a small exhaust leak since it is located off the exhaust header it is not on the pressurized side so will not effect boost? I can't see if having a big exhaust leak if any.
As you can tell I don't know a lot (anything) about turbos. :-)
Thanks for all the help.
Tom
Old May 20, 2007 | 11:12 AM
carharttfarmer's Avatar
Tom
i think that one holds the exhast half of the turbo housing on with out it you could be in for some real trouble
JP-4.5
Feb 23, 2013 08:12 AM
Bad Ramer Jamer
Dec 27, 2007 09:32 AM
90firstgen
Aug 1, 2006 06:42 PM
getblown5.9
May 23, 2006 11:47 PM
dodgediesel4x4
Jul 26, 2005 10:19 PM
